Use this guide to replace the battery in your Ecovacs Deebot 900 if it is malfunctioning or will not maintain a charge. The battery allows the Deebot 900 to maintain power without being plugged into a power source. It may become necessary to replace a malfunctioning battery.
Removing the battery when repairing anything inside the robot is also recommended for safety.
Remove all the brushes from the Deebot.
Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.
Remove the battery cover.
Anyone know where I can buy the battery for the Deebot 900. Evovacs is saying they won’t/dont sell them.
Using the two white straps on the sides of the battery, gently remove the battery.
Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
I have two issues with these instructions.
Title is Ecovacs Deebot 900 Battery Replacement. The battery was never replaced the device was reassembled.
For battery replacement you need a battery it would be nice to have the replacement battery part number as well.
I’d like some more info on part numbers, too. I have a Deebot 901 with a battery that, already after 2 years, has deteriorated significantly. Deebot 901 is also called “DE5G.10” in Europe, and it’s existing Battery back has model number ZJ1517-HFR, on which I can find almost no info, let a lone a compatible part somewhere in The Netherlands.
eymert -
crwdns2935229:08crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Great guide except no information on where to actually FIND a battery for this thing
Where can replacement battery packs be acquired from?
You can find the battery at Taobao online shopping
Amazon also sells them. Make sure to get one for the correct model though (there are alot of them)
