Ecovacs DEEBOT D35 Vacuum Motor Replacement
  1. Ecovacs DEEBOT D35 Vacuum Motor Replacement, Vacuum Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
  2. Ecovacs DEEBOT D35 Vacuum Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 9 screws that secure the back cover. Remove with a PH2 Phillips Head Screwdriver. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Vacuum Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger or plastic opening tool to separate the Deebot backside.
  4. Ecovacs DEEBOT D35 Vacuum Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the back cover from the body of the Deebot to expose the internal wiring harnesses.
  5. Ecovacs DEEBOT D35 Vacuum Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
    • There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
    • There is a multicolor wiring harness on the front center. This is represented by the orange circle.
    • Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
  6. Ecovacs DEEBOT D35 Vacuum Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 4 screws on the vacuum motor.
  7. Ecovacs DEEBOT D35 Vacuum Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from the vacuum motor body with a PH2 Phillips Head Screwdriver. The screws are:
    • 4 x 10mm screws
  8. Ecovacs DEEBOT D35 Vacuum Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the vacuum motor body
Brian
crwdns2935283:002/15/17crwdne2935283:0
475 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-2, Eyestone Spring 2017 crwdns2935289:0USF Tampa, Team 12-2, Eyestone Spring 2017crwdne2935289:0
USFT-EYESTONE-S17S12G2
thanks a lots for the valuable info
sk law - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,203
