If your Ecovacs DEEBOT D35 ever begins to miss picking up pieces of rubbish that it would normally do, use this guide in order to replace the vacuum motor part inside of it.
The motor is the main component on why vacuums produce suction. A faulty vacuum will provide no suction and failure to pick up any pieces of trash.
Before using this guide, remove any dust from the dustbin and power on the Vacuum to ensure that the issue wasn’t that the vacuum was already filled.
To replace it, installing a new one can be done by following these steps in reverse.
Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
Locate the 9 screws that secure the back cover. Remove with a PH2 Phillips Head Screwdriver. The screws are:
7 x 14mm screws
2 x 10mm screws
Use a spudger or plastic opening tool to separate the Deebot backside.
Carefully lift the back cover from the body of the Deebot to expose the internal wiring harnesses.
There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
There is a multicolor wiring harness on the front center. This is represented by the orange circle.
Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
Locate the 4 screws on the vacuum motor.
Remove the screws from the vacuum motor body with a PH2 Phillips Head Screwdriver. The screws are:
4 x 10mm screws
thanks a lots for the valuable info
