The spinning brushes are located on the backside of the DEEBOT D35 on the front right and left edge. These brushes pull dirt to the vacuum where it is suctioned up.
Roll the Deebot over on a flat surface. The brushes will be located on the front with bright yellow connectors.
Place a plastic opening tool under the lip of the brush head.
Gently pry up with the opening tool so that the brush comes out completely.
Where can I get a replacement part for the little gray piece on step 3?
