Eclipse 180G2 MP3 Video Player speaker Replacement
  1. Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  3. Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the speaker. Pull the speaker away from the device so that wires are exposed.
    • Using a wire cutter, sever the red and black cables that are connecting the speaker to the circuit board.
    • You will need to solder the new speaker wires to connect it to the device.
  • To reassemble your device after completion of replacement, follow these instructions in reverse order.
Jesse Minor
crwdns2935283:001/15/15crwdne2935283:0
668 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Tanski Winter 2015 crwdns2935289:0USF Tampa, Team 1-4, Tanski Winter 2015crwdne2935289:0
USFT-TANSKI-W15S1G4
crwdns2942667:0crwdne2942667:0 1,045
