Use this guide to remove or replace the fan clutch drum in an Echo Power Pruner 254 cc PPT2620 2019.
Pull the spark plug cap straight off of the spark plug.
Use a T25 Torx screwdriver to loosen (but not remove) the two screws clamping the main pipe assembly to the control handle.
Remove the control handle from the main pipe assembly.
Remove seven T25 screws holding together the control handle.
Lift the top half of the control handle straight up to remove it.
Lift the throttle lockout out of the control handle.
Lift the throttle trigger out of the control handle.
Pull the throttle cable sideways through the slot in the throttle trigger to remove it from the trigger.
Use a T25 Torx screwdriver to loosen (but don't remove) the screw clamping the strap hook to the handle pipe.
Remove the two T25 screws securing the handle to the handle pipe.
Slide the strap hook off the pipe and remove it.
Slide both clamps that held the handle off of the pipe and remove them.
Slide the flexible tube off of the handle pipe and remove it.
Lift the control wires out of their slots in the handle.
Lift the throttle cable out of its slots in the handle.
Slide the plastic tube holding the control wires and the throttle cable together up and off of the throttle cable. The tube will stay on the control wires.
Lift the driveshaft straight out of the handle pipe and remove it.
Use a T25 Torx screwdriver to loosen (but don't remove) the screw securing the clamp around the handle pipe.
Remove two T25 screws securing the exhaust cover: one between the cover and the fuel tank, and the other near the fan cover.
Lift the exhaust cover starting at the side nearest the fuel tank and rotate it away from the exhaust muffler assembly.
Lift the exhaust cover to remove it.
Remove two T25 screws securing the engine cover: one near the starter handle, and another near the base of the throttle cable.
Lift the engine cover straight up to remove it.
Remove the two T25 screws securing the fan cover protector.
Pull the fan cover protector straight out and remove it.
Remove the two T25 screws securing the fan cover.
Use snap ring pliers to remove the snap ring inside of the narrow end of the fan cover.
Grasp the main pipe holder with a pair of pliers and pull it straight out of the fan cover. This will take a lot of force.
Use a pair of snap ring pliers to remove the snap ring around the clutch drum.
Use a punch or a bolt to gently tap out the fan clutch drum.
Remove the fan clutch drum.
crwdns2935229:05crwdne2935229:0
crwdns2917034:0crwdne2917034:0
does the case come with the bearings in it already? if not how do you remove the bearings?
