crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Echo Dot 4. Generationcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Echo Dot 4th Generation Teardown, Open the bottom: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Open the bottom: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Open the bottom: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Get under the bottom layer with something thin and pull it off. You might need to use quite a force as it's glued pretty well.
  2. Echo Dot 4th Generation Teardown, Loosen screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Dot 4th Generation Teardown, Loosen screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the screws out with torx 6. A T5 might work as well.
  3. Echo Dot 4th Generation Teardown, Open it: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Open it: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Open it: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the device.
    • The top part is housing the speaker with all boards and components.
  4. Echo Dot 4th Generation Teardown, Take out the mainboard screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the mainboard screws with a torx 5.
  5. Echo Dot 4th Generation Teardown, Lift the mainboard.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Lift the mainboard.: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Lift the mainboard.: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful by lifting the mainboard. The LED panel and the control board are still connected.
    • Open it from the side on the volume up button.
  6. Echo Dot 4th Generation Teardown, Unplug the connectors: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Unplug the connectors: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Unplug the connectors: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take a spudger and lift the connector off. Careful! It opens from the opposite site to which the cable is going to.
  7. Echo Dot 4th Generation Teardown, Place the mainboard aside: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Best place is in the bottom part where it originaly sits.
  8. Echo Dot 4th Generation Teardown, Take out the speaker: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Take out the speaker: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Take out the speaker: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the four torx 8 screws.
    • Lift the speaker outside the speaker grill.
  9. Echo Dot 4th Generation Teardown, LED Panel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, LED Panel: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, LED Panel: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the partially glued connector cable off.
    • Use a torx 6 or 5 to take out the two screws.
  10. Echo Dot 4th Generation Teardown, Take LED panel out: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Dot 4th Generation Teardown, Take LED panel out: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull it in the direction of the arrows to take the panel out.
  11. Echo Dot 4th Generation Teardown, Take out screws of control board: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Dot 4th Generation Teardown, Take out screws of control board: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the four screws.
  12. Echo Dot 4th Generation Teardown, Loosen glued cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Dot 4th Generation Teardown, Loosen glued cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull of the glued connector cable.
  13. Echo Dot 4th Generation Teardown, Take off the cable: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Take off the cable: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Take off the cable: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the lock, which is again on the opposite side of the cable.
    • Beware pulling the cable out. Don't pull it up, pull it as low as you can. See the arrow.
    • Remember how the board is placed because there isn't much of a difference.
  14. Echo Dot 4th Generation Teardown, Lift the controller board: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Lift the controller board: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Lift the controller board: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As the controller board sits quite tight better use the flat side of a spudger to lift it off.
    • Use the leverage effect.
  15. Echo Dot 4th Generation Teardown, Closer look: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Closer look: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Dot 4th Generation Teardown, Closer look: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Thats the controller board.
    • On the other side are the buttons. Remove the rubber cap.
  16. Echo Dot 4th Generation Teardown, Screws of the device: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The device uses three types of screws.
Wolfgang
crwdns2935283:002/03/22crwdne2935283:0
542 crwdns2915208:0crwdne2915208:0
Has anyone firgured out what kind LED is used??
Helios - crwdns2934203:0crwdne2934203:0
Onde posso adquirir o cabo flex flert da echo dont 4ª geração
Eder Bezerra - crwdns2934203:0crwdne2934203:0
Hi want alaxa echo dot flex cablesvfor mother board
srinivasrao Manam - crwdns2934203:0crwdne2934203:0
I need ffc cable for alaxa echo dot mother board
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 229
crwdns2942667:0crwdne2942667:0 9,216
