Use this guide to replace the front hand guard in your Echo Chain Saw CS-590 (2019).
Make sure you have the ignition switch turned off before starting your repair.
Use your fingers to loosen the air filter cover knob.
Use your fingers to pull up and disconnect the spark plug boot.
Remove the air filter
Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
Four 24 mm-long screws
One 25 mm-long screw
Pull the handle toward the rear of the device to remove it.
Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
Push the guide bar towards the back of the device to create slack in the saw chain.
Pull the guide bar away from the device to separate the saw chain from the clutch drum.
Remove the guide bar.
Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
Pull the front hand guard toward the rear of the device to remove it.
