Echo Chain Saw CS590 2019 Carburetor Replacement
  1. Echo Chain Saw CS590 2019 Carburetor Replacement, Turn off the chainsaw: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Turn off the chainsaw: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS590 2019 Carburetor Replacement, Loosen the air filter cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Loosen the air filter cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS590 2019 Carburetor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the air filter cover.
  4. Echo Chain Saw CS590 2019 Carburetor Replacement, Disconnect the spark plug: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Disconnect the spark plug: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Disconnect the spark plug: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull up and disconnect the spark plug boot.
  5. Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the air filter: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the air filter: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the air filter: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To minimize debris entering the intake, pull the choke shut before continuing.
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  6. Echo Chain Saw CS590 2019 Carburetor Replacement, Unfasten the front handle: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Unfasten the front handle: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
    • Four 24 mm-long screws
    • One 25 mm-long screw
  7. Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the front handle: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the front handle: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the front handle: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the handle toward the rear of the device to remove it.
  8. Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the sprocket guard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the sprocket guard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
  9. Echo Chain Saw CS590 2019 Carburetor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the sprocket guard.
  10. Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the guide bar: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the guide bar: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the guide bar: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the guide bar towards the back of the device to create slack in the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar.
  11. Echo Chain Saw CS590 2019 Carburetor Replacement, Unfasten the front hand guard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Unfasten the front hand guard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the front hand guard is in the unlocked position before continuing.
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
  12. Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the front hand guard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the front hand guard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the front hand guard toward the rear of the device to remove it.
  13. Echo Chain Saw CS590 2019 Carburetor Replacement, Unfasten the engine cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Unfasten the engine cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T25 Torx screwdriver to remove the three 20 mm screws securing the engine cover.
  14. Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the engine cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the engine cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the engine cover: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the engine cover straight off the device to remove it.
  15. Echo Chain Saw CS590 2019 Carburetor Replacement, Unfasten the carburetor cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Unfasten the carburetor cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T25 Torx screwdriver to remove the two 54 mm screws securing the carburetor cover.
  16. Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the carburetor cover: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the carburetor cover: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the carburetor cover: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the carburetor cover straight off its housing to remove it.
  17. Echo Chain Saw CS590 2019 Carburetor Replacement, Disconnect the carburetor: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Disconnect the carburetor: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Disconnect the carburetor: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before performing this step, put on safety glasses to avoid any fuel spraying in your eyes.
    • Use your fingers to pull the right fuel pipe out of the carburetor.
    • Repeat the same procedure for the left fuel pipe.
  18. Echo Chain Saw CS590 2019 Carburetor Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the choke lever through its bracket to separate it from the frame.
    • Twist the lever counter-clockwise to disconnect its clip on the carburetor.
    • Remove the choke lever.
  19. Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the carburetor: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the carburetor: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS590 2019 Carburetor Replacement, Remove the carburetor: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the carburetor out of its housing.
    • Twist the carburetor counter-clockwise to disconnect the throttle rod's metal clip.
    • Remove the carburetor.
crwdns2935229:09crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
173.845 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.719crwdne2935297:0
And what about using a new carburetor gasket? Got a part # to go with it?
TED - crwdns2934203:0crwdne2934203:0
steps 6 to 14 are unnecessary they have nothing to to with the removal or install
HECTOR - crwdns2934203:0crwdne2934203:0
What about the set-up is the carb preset and you just drop it in or does it need adjustment.
JOHN - crwdns2934203:0crwdne2934203:0
My saw won't start, how do you determine if it's a bad carburetor or a bad ignition coil?
STANLEY - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 54
crwdns2936753:030crwdne2936753:0 182
crwdns2942667:0crwdne2942667:0 3,319
