Echo Chain Saw CS4910 2020 Carburetor Replacement
  1. Echo Chain Saw CS4910 2020 Carburetor Replacement, Turn off the chainsaw: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Turn off the chainsaw: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS4910 2020 Carburetor Replacement, Loosen the air filter cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Loosen the air filter cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the air filter cover.
  4. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  5. Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the spark plug: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the spark plug: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the spark plug: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull up and disconnect the spark plug boot.
  6. Echo Chain Saw CS4910 2020 Carburetor Replacement, Loosen the sprocket guard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Loosen the sprocket guard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 13 mm wrench to loosen and remove the two nuts securing the sprocket guard.
  7. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the sprocket guard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the sprocket guard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the sprocket guard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the sprocket guard straight off its two pegs and remove it.
  8. Echo Chain Saw CS4910 2020 Carburetor Replacement, Unclip the saw chain: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Unclip the saw chain: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put on gloves before performing the next two steps.
    • Pull the saw chain away from the tip of the guide bar to unclip it.
  9. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the guide bar: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the guide bar: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the guide bar: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the guide bar towards the back of the device to unclip the rest of the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar and the saw chain.
  10. Echo Chain Saw CS4910 2020 Carburetor Replacement, Unfasten the engine cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Unfasten the engine cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flathead screwdriver, or a 3 mm hex key, to remove the three 18 mm screws securing the engine cover.
  11. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the engine cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the engine cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the engine cover: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the engine cover straight up off the engine.
    • Remove the engine cover.
  12. Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the carburetor: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the carburetor: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the carburetor: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before performing this step, put on safety glasses to avoid any fuel spraying in your eyes.
    • Use your fingers to pull the top-most fuel pipe out of the carburetor.
  13. Echo Chain Saw CS4910 2020 Carburetor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the choke rod out of its recess in the chassis.
    • Twist the rod counter-clockwise to disconnect it from the carburetor.
    • Remove the choke rod.
  14. Echo Chain Saw CS4910 2020 Carburetor Replacement, Unfasten the carburetor: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Unfasten the carburetor: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws securing the carburetor and the air filter adapter:
    • Use a 3 mm hex key to remove the two 20 mm-long screws.
    • Use a 4 mm hex key to remove the two 53 mm-long screws.
  15. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter adapter: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter adapter: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter adapter: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the air filter adapter straight off the carburetor and remove it.
  16. Echo Chain Saw CS4910 2020 Carburetor Replacement, Reposition the carburetor: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Reposition the carburetor: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the carburetor's choke valve facing you, tilt the carburetor up and to the left to expose the right-most fuel pipe.
  17. Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the right fuel pipe: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the right fuel pipe: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to disconnect the right-most fuel pipe.
  18. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the carburetor: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the carburetor: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the carburetor straight off the throttle rod and remove it.
    • Realign throttle rod upon reassembly.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
173,845 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,719crwdne2935297:0
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 1,277
