Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement
  1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grip the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Disconnect the control cables: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Disconnect the control cables: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip the throttle cable routing clip from the main shaft.
  3. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip both ends of one of the control cable bullet connectors and pull to disconnect it.
    • Repeat to disconnect the second control cable connector.
    • These connectors are interchangeable.
  4. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the muffler cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the muffler cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This Echo device has an included multi-tool with a T30 Torx screwdriver, but any T30 Torx driver is compatible.
    • Use a T30 Torx driver to remove the two screws securing the muffler cover.
  5. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the muffler cover up and pivot it on its top edge to unlatch it from the engine cover.
    • Remove the muffler cover.
  6. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the engine cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the engine cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T30 Torx driver to remove the two screws securing the engine cover.
  7. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the engine cover straight up to remove it.
  8. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the fan cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T30 Torx driver to remove the two screws securing the fan cover.
  9. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the fan cover away from the motor assembly.
  10. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Reassembly tip: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Reassembly tip: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly:
    • Reroute the two control cables through the opening on the fan cover.
    • Lay the cables into their slot on the clutch cover.
  11. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Separate the shaft from the engine assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T30 Torx driver to loosen, but not remove, the collar bolt securing the main shaft to the engine assembly.
  12. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the engine assembly and pull to remove it from the main shaft.
    • With the engine assembly removed, take care to not put any strain on the still-connected throttle cable.
  13. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the clutch cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T30 Torx driver to remove the two screws securing the clutch cover.
  14. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the clutch cover.
  15. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the clutch assembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2 inch socket to remove the two 12 mm-long bolts and four accompanying washers securing the clutch assembly.
    • Note that the larger washer goes underneath the clutch assembly and the small washer goes above.
    • Ensure that the clutch assembly is reinstalled arrow side up.
  16. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the clutch assembly.
Carsten Frauenheim
146.140 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.823crwdne2935297:0
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 1,298
