EasySMX X15 D-Pad Replacement
  1. EasySMX X15 D-Pad Replacement, Bottom Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EasySMX X15 D-Pad Replacement, Bottom Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
  2. EasySMX X15 D-Pad Replacement, Main Board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the vibration motor cables from the connectors on the circuit board.
    • Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
  3. EasySMX X15 D-Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the board away from the upper casing, maneuvering it around the triggers by lifting it from the bottom, away from the upper casing.
  4. EasySMX X15 D-Pad Replacement, D-Pad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EasySMX X15 D-Pad Replacement, D-Pad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the four 4 mm screws securing the D-pad to the controller casing.
    • Lift the back of the D-pad, along with the membrane, to remove them from the controller.
    • Lift up the case, allowing the D-pad to detach from the top of the casing.
Cameron Gattis
crwdns2935283:009/09/24crwdne2935283:0
173 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 7-3, Watkins Fall 2024 crwdns2935289:0Austin Community College, Team 7-3, Watkins Fall 2024crwdne2935289:0
AUSTINCC-WATKINS-F24S7G3
crwdns2942667:0crwdne2942667:0 128
