EasySMX X15 Battery Replacement
  1. EasySMX X15 Battery Replacement, Bottom Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EasySMX X15 Battery Replacement, Bottom Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
  2. EasySMX X15 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EasySMX X15 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EasySMX X15 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push on alternating sides of the connector to disconnect the red battery cable from the board.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Pull from the tab, not the cables, to avoid damaging them.
  3. EasySMX X15 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry the battery loose from the controller.
    • The battery is glued onto the control board, so it may take a bit of work to release it from the adhesive.
    • Remove the battery.
    • Don't bend or pierce the battery. If the battery is swollen, follow the guidelines outlined in this article.
ShawnDetiveaux
crwdns2935283:009/09/24crwdne2935283:0
637 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 7-3, Watkins Fall 2024 crwdns2935289:0Austin Community College, Team 7-3, Watkins Fall 2024crwdne2935289:0
AUSTINCC-WATKINS-F24S7G3
What battery do i need compatible with this controller? where i can find it?
Manel Leiva - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 478
