EasySMX ESM-9110 Backplate Replacement
  1. EasySMX ESM-9110 Backplate Replacement, Handle Covers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 EasySMX ESM-9110 Backplate Replacement, Handle Covers: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
  2. EasySMX ESM-9110 Backplate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a plastic opening tool into the slit on the side of controller.
    • Wiggle the tool until the cover becomes loose.
    • Repeat this on the other side of Controller.
    • Go slow. Take your time removing the handle covers.
  3. EasySMX ESM-9110 Backplate Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the faceplate.
    • Repeat on the other side of the controller.
  4. EasySMX ESM-9110 Backplate Replacement, Backplate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EasySMX ESM-9110 Backplate Replacement, Backplate: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EasySMX ESM-9110 Backplate Replacement, Backplate: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
    • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
    • Screw extender should only be used to unscrew two of the six screws. Do not use for all six.
  5. EasySMX ESM-9110 Backplate Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the faceplate of the controller by lifting it directly up from the backplate.
    • Be gentle. The controllers backplate is still attached to the faceplate.
  6. EasySMX ESM-9110 Backplate Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 EasySMX ESM-9110 Backplate Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 EasySMX ESM-9110 Backplate Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the daughterboard off the backplate.
    • Remove the daughterboard once screws are off.
    • Be gentle when removing the daughterboard. The daughterboard is still attached to the faceplate.
Melanie Rodriguez
crwdns2935283:003/18/24crwdne2935283:0
406 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-4, Konn Spring 2024 crwdns2935289:0UMass Dartmouth, Team 2-4, Konn Spring 2024crwdne2935289:0
UMASSD-KONN-S24S2G4
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 357
