This guide contains steps for replacing faulty clickers on the EVGA x17 gaming mouse. Malfunctioning clickers might be due to gunk buildup, broken parts, or faulty wiring. Follow this guide for instructions of how to replace them.
            Remove the mouse skates to reveal 5 screws.
            Use a Phillips head screwdriver to remove the 5 screws that secure the bottom panel.
            Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
            Remove the 13 screws on the interior.
            Carefully slide the middle section out.
            Remove the two screws from each clicker.
            Pop and slide out each clicker that needs to be replaced.
Tengo un Evga x17 y cuando quitó los sliders, encuentro unas pequeñas capas de plástico que tapan el acceso a los tornillos, ¿qué puedo hacer en ese caso?
