ESGE Magic Wand - Bamix disassemble
  1. ESGE Magic Wand - Bamix disassemble, Remove top cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ESGE Magic Wand - Bamix disassemble, Remove top cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ESGE Magic Wand - Bamix disassemble, Remove top cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Unplug the power cord and remove the cutter blade.
    • The top cover is fastened with two Torx TR10 security screws. These screws are different from normal Torx screws: they are equipped with a center pin. Use the right bit or screwdriver with center hole.
    • Remove two Torx TR10 screws.
    • Carefully lift off the cover. It is latched at the front.
  2. ESGE Magic Wand - Bamix disassemble: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ESGE Magic Wand - Bamix disassemble: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ESGE Magic Wand - Bamix disassemble: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is what it looks like under the cover.
    • Slide out the two buttons and the small circuit board. The buttons are only snapped in.
  3. ESGE Magic Wand - Bamix disassemble: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ESGE Magic Wand - Bamix disassemble: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The handle is fastened with a Torx T8 machine screw and a Torx T8 plastic screw. You will need a long screwdriver.
    • Remove two Torx T8 screws.
  4. ESGE Magic Wand - Bamix disassemble: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ESGE Magic Wand - Bamix disassemble: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ESGE Magic Wand - Bamix disassemble: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On newer models, the handle looks slightly different, see picture 1.
    • Carefully press the two catches on the switch module down a little. Then pull the module inwards a little.
    • Carefully pull the switch module out of the device.
    • Unscrew the Torx T8 screw and the Torx T10 screw inside.
    Habe die Kabel zum Motor aus der Platine ausgelötet - das erschien mir einfacher als das Schaltermodul und das ganze Kabel durch's das Oberteil zu bugsieren.
    Martin - crwdns2934203:0crwdne2934203:0
    Ja, das ist auch eine gute Möglichkeit.
    VauWeh -
  5. ESGE Magic Wand - Bamix disassemble: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ESGE Magic Wand - Bamix disassemble: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip the handle from one side.
    • Unthread the cable, the buttons and the board.
    • The motor ist exposed. However, it is not yet completely accessible, since the lower plastic housing part cannot yet be slid over the bell. The bell must first be removed.
    Super Anleitung, habe den Zauberstab zerlegt, die Welle gereinigt und wieder zusammengesetzt. Einwandfrei.
    Georg Strasser - crwdns2934203:0crwdne2934203:0
  6. ESGE Magic Wand - Bamix disassemble: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ESGE Magic Wand - Bamix disassemble: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ESGE Magic Wand - Bamix disassemble: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First try If the bell can be unscrewed. It is fastened with a left-hand thread, so turn it in the "wrong direction", clockwise, to loosen it.
    • Pull on the knife to remove it
    • The bell sits probably quite tight, as it should not come loose during normal operation. When reassembling, glue it in place with a few drops of fluid threadlocker, if needed.
    • If it does not come off easily, then slide the lower plastic part towards the bell and clamp the motor in a vice. Do not tighten the vice very much, the motor is sensitive.
    • Use a long screwdriver as a lever between the bell and the shaft. Then carefully unscrew the bell. Reminder: the wrong way round, i.e. clockwise.
    • Pay attention to the washer between the shaft and the bell, do not lose it.
    Es fehlt leider wie man das Messer entfernt bevor man die Glocke entfernen kann, wäre super wenn man den Schritt noch hinzufügt.
    kapott - crwdns2934203:0crwdne2934203:0
    Aber das ist doch das "normale" Wechseln der Einsätze (gibt ja verschiedene), so wie in der Gebrauchsanleitung beschrieben. Es kann halt nur sein, dass er nicht oft abgenommen wurde (sollte man tun, um ihn sauber zu halten) und deswegen festklebt. Dann in heißem Wasser erwärmen und vorsichtig mit einer Zange abziehen oder einem starken Schraubendreher abhebeln. Wenn dann der Messereinsatz zu leicht geht, kann man die Metallraste vorsichtig mit der Zange zusammen drücken.
    VauWeh -
  7. ESGE Magic Wand - Bamix disassemble: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the lower case over the shaft.
    Leider endetz die Erklärung zu früh. Beimeinem Gerät dreht sich die Welle nicht bei eingeschaltetem Motor.Der Motorläuft alleine perfekt-Offensichtlich ist mit der Kupplung zwischen Motor und Welle etwas nicht in Ordnung. Wie kann man dioes eaustauschen bzw. prüfen-?
    Saronni - crwdns2934203:0crwdne2934203:0
    Da durfte die Gummikupplung am oberen Ende der Welle gerissen sein In dieser Anleitung, Schritt 8, drittes Bild ist das Teil gut zu sehen. Eine Schraube ist eingegossen, die muss herausgedreht werden, dann kann das Ersatzteil eingedreht werden, leider relativ teuer, google nach Gummikupplung ESGE.
    VauWeh -
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
266,450 crwdns2915208:0crwdne2915208:0
crwdns2935297:0301crwdne2935297:0
Danke für die Anleitung.
Mein Zauberstab fängt sehr schnell an schleppend zu laufen (irgendwo entsteht Wiederstand), wird langsamer, wenn ich heisse Sachen püriere. Woran könnte das liegen?
LG Aaron
Aaron - crwdns2934203:0crwdne2934203:0
Da würde ich wirklich die Achse freilegen und mit etwas Silikonöl schmieren.
VauWeh -
Auch dir Danke für die Anleitung.
Mein Modell ist ein M100 aus dem Fundus meiner Tante und schon sicher über 35-40 Jahre alt.
Torx-Schrauben waren damals noch unbekannt.
Daher ging Schritt 3 leider nicht. Vielmehr sind 2 Kreuzschlitzschrauben unter 2 Kunststoff-Stopfen versteckt. Diese konnte ich nur mit einem kleinen Trick aus dem Gehäuse entfernen: 1 Tropfen Heißkleber und ein unten abgeschnittener Thai-Spieß als Griff. Ich habe da Fotos von gemacht, aber da ich neu hier bin, weiss ich nicht, wo hoch laden bzw. wie man die Anleitung editiert.
Wenn sich da jemand auskennt, gerne sagen, dann sende ich die Fotos zu.
Liebe Grüße
falo_hu - crwdns2934203:0crwdne2934203:0
Die Anleitung ist sehr hilfreich.
Ein Tipp zum Lösen der Glocke: Wer das erste Lösen der Glocke schon ganz am Anfang macht, hat das Gerät über den noch befestigten Griff viel sicherer in der Hand. So ging es zumindest bei meinem Exemplar sehr einfach.
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 93
crwdns2936753:030crwdne2936753:0 373
crwdns2942667:0crwdne2942667:0 16,668
