ELENCO XP-720K Voltage Control Potentiometers Replacement
  1. ELENCO XP-720K Voltage Control Potentiometers Replacement, Remove old potentiometers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ELENCO XP-720K Voltage Control Potentiometers Replacement, Remove old potentiometers: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ELENCO XP-720K Voltage Control Potentiometers Replacement, Remove old potentiometers: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • UNPLUG Power Supply from any external power and disconnect all cables.
    • Remove the two #1 philips head screws from the sides of the power supply.
    • Take a photograph of your wiring before starting to make sure you get them back correct.
    • Using your desoldering equipment desolder the 4 leads going to the two voltage control potentiometers.
    • Remove the 2 potentiometers and all their hardware.
  2. ELENCO XP-720K Voltage Control Potentiometers Replacement, Install new potentiometers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ELENCO XP-720K Voltage Control Potentiometers Replacement, Install new potentiometers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ELENCO XP-720K Voltage Control Potentiometers Replacement, Install new potentiometers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To fix this it was a simple fix of replacing the 2K Ohm standard potentiometers for voltage adjustment with a 10 turn precision potentiometer.
    • Insert the new potentiometers in their places.
    • Solder all four wires back to each post.
    • Put new 10 turn knobs on the front.
    • Plug power supply in and test functioning.
    • Put cover back on with four #1 philips screws.
    • You are done.
You are replacing VR1 & VR2 which are the 2 K voltage adjustment potentiometers for the variable power supplies. See page 18 of the pdf
Link to part on Amazon. https://www.amazon.com/dp/B07MQ7R5C7/?co...
crwdns2935103:0crwdne2935103:0
rickwag
crwdns2935283:010/18/10crwdne2935283:0
1,266 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 45
