Follow this guide to remove and replace the power cord on an EDCO Floor Stripper TS8 .75L (2017).
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a Phillips screwdriver to remove the screw from the center of the red on/off knob.
Remove the black plastic cap from the center of the switch assembly.
Use a Phillips screwdriver to remove the two screws securing the yellow switch guide to the switch assembly.
Remove the yellow switch guide from the switch assembly.
Remove the black plastic spacer from underneath the yellow switch guide.
Use a Phillips screwdriver to remove the four screws securing the upper half of the switch housing to the lower half.
Lift the upper half of the switch housing off of the lower half."
Use a 3/8 inch socket to remove the bolt securing the power cord loom clamp to the switch bracket.
Remove the loom clamp from the power cable.
Use a socket to remove the four 11/32 inch nuts from the on/off switch bracket.
Lift the switch assembly off of the switch bracket.
Use a flathead screwdriver to remove the screw securing the two green ground wires to the switch housing.
Separate the green ground wires from each other and move them away from the switch housing.
Use a flathead screwdriver to loosen the two screws on the right side of the switch assembly securing the black and white wires from the power cord.
Remove the black wire from the switch.
Remove the white wire from the switch.
Use a 1-1/16 inch wrench or an adjustable wrench to loosen the power cord's strain relief fitting from the switch housing.
Once the fitting is loose enough to turn by hand, twist the power cord and fitting counterclockwise until it is fully unthreaded from the switch housing.
Remove the power cord from the on/off switch.
Use two adjustable wrenches to unscrew the strain relief fitting by turning the locknut counterclockwise relative to the fitting.
1-1/16 inch lock nut
15/16 inch strain relief fitting
Remove the lock nut from the power cord.
Insert a flathead screwdriver into the fitting and push the blue grommet out to remove it from the housing.
Remove the fitting from the power cord.
Remove the grommet from the power cord.
Remove the remaining nut and washer from the power cable.
