Dyson V8 Animal Battery Replacement
  1. Dyson V8 Animal Battery Replacement, Bin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson V8 Animal Battery Replacement, Bin: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the red button and slide the connecting shaft off.
    • The shaft must be held from moving when disconnecting from the motor.
  2. Dyson V8 Animal Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson V8 Animal Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson V8 Animal Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the red tab and continue to slide the motor completely up.
    • The dust bin will open on the bottom.
  3. Dyson V8 Animal Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson V8 Animal Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the red tab down.
    • Pull the dust bin out from the handle head.
  4. Dyson V8 Animal Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson V8 Animal Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down on the red tab.
  5. Dyson V8 Animal Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson V8 Animal Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down on the red tab on the other side.
    • Pull the motor away from the handle.
    • You may need to hold down the handle while sliding the motor off.
  6. Dyson V8 Animal Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson V8 Animal Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove two 18 mm screws on the bottom of the battery.
  7. Dyson V8 Animal Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove one 18 mm screw on the back of the handle.
  8. Dyson V8 Animal Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson V8 Animal Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery out from handle.
    • The handle must be held from moving while sliding the battery out.
crwdns2935229:014crwdne2935229:0
AJ McLean-Scholz
crwdns2935283:001/23/20crwdne2935283:0
783 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G1, White Winter 2020 crwdns2935289:0Cal Poly, Team S19-G1, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S19G1
crwdns2947412:07crwdne2947412:0
Replacement Vacuum Cleaner Batteries for Dyson V8 Animal
Battery Type:   Li-ion
Voltage:   21.6V
Capacity:   4000mAh
Color:   Grey
Weight:   770.26g
Dimensions: 145.00 x 90.10 x 115.90mm
If you intereted in this battery, please view more info on http://www.drillbattery.com.au/orderbatt...
Drillbatterycomau - crwdns2934203:0crwdne2934203:0
Thankyou! I'll be able to replace the battery soon.
Olivia Swift - crwdns2934203:0crwdne2934203:0
This worked for the V7 Animal model just fine. Very easy and clear, thank you!
Katie - crwdns2934203:0crwdne2934203:0
Thank you. These instructions just helped me to replace the worn out battery on our V8 Animal in 5 minutes! Now it's humming along again with 3 blue bars. Great! (Note: I was concerned I might strip the screw head but I just pressed harder while turning and the screwdriver did not slip. Then I saw that the replacement battery came with four new replacement screws. So, it's all good.)
Neill Graham - crwdns2934203:0crwdne2934203:0
I have a stripped screw that won't extract. I have already drilled the hole ho so now no screwdriver will work. Any suggestions?
christina - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 226
crwdns2942667:0crwdne2942667:0 9,820
