Dyson V8 Absolute Battery Replacement
crwdns2942287:0crwdne2942287:0In case the device is not turning on and the battery has been completely charged for 5 hours, the battery may need to be replaced. The battery can be easily removed and replaced.
crwdns2944105:0crwdne2944105:0
Use a Phillips #2 screwdriver to unscrew the screw from the device handle.
Turn device completely over to view battery pack.
Below the bin, use a Phillips #2 screwdriver to remove both screws from the battery pack.
Pull the battery pack down and away from the device.
Juste pour dire 170 mm de vis c’est 17 CENTIMÈTRES de vis … apprend à te servir d’un mètre ruban
Les miennes font 15 mm soit 1.5 cm
Merci pour votre aide
Worked like a charm. My Mom's Dyson v8 was not charging after she came back from a long vacation. Installing the replacement battery with these easy instructions and the vacuum was working like new. The Serial Number and original information could not be moved over to the replacement battery. Just took a picture and put away in a folder for future reference.
What does it mean when blue lights flash as if it’s charging then goes dark?
Hi Shannon
While charging the three LEDs show the state of charge.
LED 1 flashing: battery is charging in range 0 to 33 %LED 1 solid and LED 2 flashing: battery is charging in range 33 to 66 %
LED 1 + LED 2 solid and LED 3 flashing: battery is charging in range 66 to 100 %
If all LEDs switch off after the step above the battery pack is fully charged.
If the LEDs flash blue when you push the button then it means you have to connect it to the charger.
If the vacuum shuts off during work because of an empty battery it remembers this shut off state and starts working only after you connected it to the charger.
Was this your question? :-)
Gracias. Muy fácil pero hay que saberlo.
crwdns2935229:059crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:016crwdne2947412:0
Great instructions!!
I have replaced the battery and I still got a flashing red light, any ideas
I replaced my battery and charged the new one- my vac doesnt work
if you have got the switch on max slide other way plug it to charge for 3,4 minuite then try should work. do not put on max as it will not work and you will have to do it all over again
My v8 animal has a new battery but it doesn't seem to want to charge. The 1st of the 3 battery lights lights up constantly, the 2nd just flashes and the 3rd never lights up no matter how long it's left on charge. The motor will run ok on the lower setting but cut's out almost instantly in the highest setting.
Could the charger be at fault?
straightforward easy to follow instructions battery may need a bit of a light jiggle to engage the trigger switchgear on reassembly but no problems encountered
Good instructions. Easy to follow. Now we can clean our floors again! Thanks!
I have unsrewed three screws but my battery seems to be stuck as it will only slide out a little but won’t slide out the whole way. Any suggestions??
How long do batteries last? I’ve had mine for 3 years and I’m surprised it’s stopped working.
I've used mine less a dozen times; still has the stickers on it. Doesn't work. Light flashes red then blue when trigger is held. Why is it not working?!
What size battery do I need for Dyson Seral No. RB2-AU-KHA3272A
Got new battery for my v8 , charged it and nothing.
volendo sostituire la batteria del v8 posso metterla una piu grossa e resistente
Have only used my V8 once. Plugged it back in and now get nothing, no lights absolutely nothing. Tried in a different power point same thing. What has gone wrong ??
New battery, charged up originally, now no lights on, no charge.
Replacement Vacuum Cleaner Battery for Dyson V8 Absolute
Type: Li-ion
Volt: 21.6V
Capacity: 4000mAh
Color: Grey
Weight: 570.26g
Dimension: 145.00 x 90.10 x 115.90mm
This Dyson V8 Absolute battery can be charged with original battery charger. All vacuum cleaner batteries include a minimum 12 Months Warranty, 30-Day Money Back and Fast Delivery by Drill Battery Store in United States.
