Require battery removal, which is not included due to device not having a battery. Connection tubing will need to be removed before motor replacement.
Pull down on the red release tab.
Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head.
Pull the collection bin away from the upper vacuum head.
Identify the two white components between the vacuum handle and the attached component.
Insert each arm of the tweezer into each white component area and squeeze simultaneously to release the motor from the attached component.
Detach the motor from the remaining motor head assembly.
crwdns2935229:010crwdne2935229:0
really good can understand and not too technical
I am terrible at fixing things and this helped me put my vacuum back together after it fell and the motor detached from the handle. Thank you!!!
Can't see the tweezer being inserted into the white tabs. Picture not clear. Could not dislodge motorhead from cannister bin. Show a clearer picture. Thanks
