A hairdryer is commonly used in our daily life, sometimes users forgot how important cleaning your device is. This guide is mainly focused on replacing and cleaning the Dyson Supersonic HD03 hairdryer filter. Whenever users encounter operation failure or weird noises, there are high chances that the hairdryer’s filter is blocked with dust or hair. Cleaning your hairdryer filter will help you avoid operation failure and increase your device life span. This guide will show you how to clean and replace your filter.
For further detailed information, you can visit Dyson Official.
Remove the dirty filter cage by twisting the filter towards the left.
The filter cage will be unlocked when the red dot matches the white thin circle.
Soak the filter cage in dish soap and warm water for at least 30 minutes.
Use the supplied filter cleaning brush or any other cleaning tool to vigorously scrub the soaked filter cage.
Be sure to remove all blockages.
Rinse and dry your filter cage.
Check that the filter cage is clean by holding it up to the light - you should be able to see light through it. If you can't, repeat the previous step.
Insert the filter back into the filter cage and install the filter cage back onto the device.
The filter cage will be locked when the red dot matches the white filled circle.
crwdns2917034:0crwdne2917034:0
My Dyson hair dryer has quitting every 30 seconds - apparently overheating. It was very easy to remove the filter cage and wipe the filter clean. Problem solved!
