This guide will show you how to open and replace the bin of your Dyson DC58.
Make sure your vacuum is unplugged.
Locate the red lever parallel to the red trigger and on the side of the clear bin.
Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
The bin is stuck and won’t come off, although I have followed the directions above.
I think the reassembly instructions should be numbered “Step 5” and printed right below Step 4. They aren’t that easy to see.
