Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble
  1. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the chassis: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the unit over and remove the 4 Torx T15, 18mm pan head screws.
  2. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the wheels: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the T15 21mm countersunk head screw and pull the wheel off (on each side)
  3. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the screws in the case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the screws in the case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 8 Torx T15, 22mm pan head screws from the bottom…
    • and the 2 22mm Torx T15 screws from the top.
  4. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the screws on the upper air pipe: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the screws on the upper air pipe: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the screws on the upper air pipe: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the button to release the dust container.
    • Carefully press the locking lugs inwards with a screwdriver or by hand until the upper part with the suction tube can be folded further upwards.
    • Then another 2 Torx T15, 18 mm cylinder head screws become visible, which are removed (they fasten the cable drum on the inside).
  5. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Loosen the intake manifold holder screw: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the one PH2 screw of the intake manifold holder (it fastens the cable drum on the inside).
  6. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the lower case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the case halves apart. You now have the HEPA filter and the cable drum in the upper half and the motor in the motor capsule in the lower half.
  7. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the upper case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The upper part is clipped into the housing with 2 locking notches. Try to unhook with a screwdriver and some hand wiggling. Don't grab the HEPA filter too tightly as it is made of paper and is easily dented.
  8. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Loose the cable from the motor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Loose the cable from the motor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Loose the cable from the motor: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The switch is on the cable drum. The cable is connected to a blade connector which is secured by a fine tab to prevent vibration from loosening it. If you press on the lug with a fine screwdriver, the connection can be released without too much force. Disconnect the black cable.
    • Next to it is a long, black box in which the white cable is plugged. Press the lug with the screwdriver here as well and loosen the plug connection.
    • Then carefully pull both cables out of the strain relief on the housing.
    • Now you have mechanically and electrically separated the motor from the cable drum.
  9. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove HEPA filter: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To separate the cable reel and the HEPA filter, hold the HEPA filter carefully and turn the cable reel approx. 90° clockwise. Then both parts can be separated.
    • Done. You have separated the essential main parts.
    • The cable reel, the HEPA filter and the motor can be easily obtained as spare parts on the Internet. The filter is available for around 60 euros, the motor and cable drum for around 80 euros.
    • During reassembly it can easily happen that the cable drum is stressed. In this case the vacuum works well but the cable will not automatically rewind if you press the button.
    • Therefore you have to assure that the white notches (see step 7) fit in the corresponding openings and not being pushed deeper.
    • Thighten the 2 Torx screws from step 4 and the PH2 screw from step 5 only very little. Always test the rewinding function of the cable. Only at the end if the rewinding works well, tighten these screws and close the lid with the suction tube.
crwdns2935229:010crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
HowThingsWork
crwdns2935283:007/21/21crwdne2935283:0
3,180 crwdns2915208:0crwdne2915208:0
Thank you, it worked as described. The hardest part is step 7, as the white lugs are solidly part of the body and have no "give". Undoing them requires prising between the lug and the shell forcefully with a fine screwdriver to spring the shell locating tag off. There is then a lug down by the cable entry which is easily sprung with a fine screwdriver. For reassembly I was able to use fine snipe-nose pliers to grasp a piece of the white body through the opening on the switch side and pull the lug into position. The other lug was harder but I made a small hole in the lug with a small screwdriver and used it to drag the lug into position.
Chris P - crwdns2934203:0crwdne2934203:0
aidapulley - crwdns2934203:0crwdne2934203:0
Merci pour ce tuto qui a très bien fonctionné. On confirme la galère pour le démontage de l'étape 7 et le remontage à la même étape.
Anne Rives - crwdns2934203:0crwdne2934203:0
Merci beaucoup pour ce tuto sans lequel je n'aurai pas réussi à changer le moteur de mon aspirateur. Bertrand
Bertrand Duprat - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 18
crwdns2936753:07crwdne2936753:0 98
crwdns2936753:030crwdne2936753:0 442
crwdns2942667:0crwdne2942667:0 14,803
