Dyson DC28 Animal Wheel Replacement
  1. Dyson DC28 Animal Wheel Replacement, Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the vacuum face down with the wheels facing up.
  2. Dyson DC28 Animal Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start on the right side wheel of the vacuum cleaner
    • Remove the plastic wheel cap by sliding the tip of the metal spudger under the edge of the cap.
    • Gently pry off the plastic cap
  3. Dyson DC28 Animal Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson DC28 Animal Wheel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson DC28 Animal Wheel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the e-clip located under the metal axle.
    • The e-clip is very small and may be hard to identify. It is a small metal ring between the metal axle and the plastic wheel.
    • Use the metal spudger to pry off the e-clip.
    • The e-clip is hard to remove and may require extra force.
  4. Dyson DC28 Animal Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC28 Animal Wheel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide off the plastic wheel off of the metal axle
    • Be careful when removing plastic wheel. There is a loose metal washer and black axle piston behind the wheel that can easily fall off.
    • Slide off the metal washer and black axle piston from the metal axle
  5. Dyson DC28 Animal Wheel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal axle by pulling on the left wheel. This does not take a lot of force and should easily slide out.
    • Repeat steps 2, 3, and 4 to remove the left side wheel from the metal axle.
Zachary Urciuoli
crwdns2935283:001/27/17crwdne2935283:0
Cal Poly, Team 21-4, Maness Winter 2017 crwdns2935289:0Cal Poly, Team 21-4, Maness Winter 2017crwdne2935289:0
CPSU-MANESS-W17S21G4
crwdns2942667:0crwdne2942667:0 3,177
