This guide will detail how to remove the plastic wheels to take out any obstructions blocking movement or replace the wheels if cracked or damaged.
Flip the vacuum face down with the wheels facing up.
Start on the right side wheel of the vacuum cleaner
Remove the plastic wheel cap by sliding the tip of the metal spudger under the edge of the cap.
Gently pry off the plastic cap
Identify the e-clip located under the metal axle.
Use the metal spudger to pry off the e-clip.
Slide off the plastic wheel off of the metal axle
Slide off the metal washer and black axle piston from the metal axle
Remove the metal axle by pulling on the left wheel. This does not take a lot of force and should easily slide out.
Repeat steps 2, 3, and 4 to remove the left side wheel from the metal axle.
