Dyson DC28 Animal Air Muscle Assembly Replacement
  1. Dyson DC28 Animal Air Muscle Assembly Replacement, Sole Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Coin
    $2.99
    • Lay the vacuum on its side to allow for easy access to the bottom of the cleaner head.
    • Unlock the sole plate by using a quarter or other flat tool to turn the three plastic bolts counter-clockwise, as indicated on the sole plate.
    • The plastic fasteners can be damaged when using a metal tool to turn them.
  2. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull off the sole plate
  3. Dyson DC28 Animal Air Muscle Assembly Replacement, Air Muscle Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the dust collector using the red button located at the top of the bin
  4. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the vacuum over to allow for easy access to bottom.
  5. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the 6 screws.
    • Remove the six 9mm screws using T15 Torx Screwdriver.
  6. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the drive cover.
  7. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the drive assembly.
  8. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the hose by hard plastic base.
    • Pull firmly to remove it from the holder.
    • If you pull too hard the plastic can be ripped.
  9. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grab top section of the hose and remove from the holder.
  10. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove section of the hose from the vacuum.
  11. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Go to the wheel on the right side of the vacuum.
    • Remove the cap of wheel by sliding in a small metal spudger or flat head screwdriver and gently prying up.
  12. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Metal Spudger
    $2.99
    • Use the pointed end of a metal spudger to pull off the e-clip.
    • The e-clip is hard to remove and may require some effort to remove.
  13. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the wheel off of the axel.
  14. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the axel piston from axel.
    • Be careful not to lose the washer on the end of the axel piston.
  15. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Flush Cutter
    $29.99
    • Use the wire cutters to cut the zip tie holding the tube on.
    • Be careful not to cut the plastic hose.
  16. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry and pull the tube off of the nub.
  17. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a flat head screwdriver or metal spudger to push the plastic out of the way and remove the air muscle.
    • Be careful not to break the plastic. Bend it just enough to remove the part.
  18. Dyson DC28 Animal Air Muscle Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the air muscle from the rest of the vacuum.
Alec Goodman
crwdns2935283:001/25/17crwdne2935283:0
222 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-4, Maness Winter 2017 crwdns2935289:0Cal Poly, Team 21-4, Maness Winter 2017crwdne2935289:0
CPSU-MANESS-W17S21G4
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 10,334
