The brush bar on the vacuum can wear with use. If your brush is scratching your floor, or not cleaning as well as it used to, then you may want to replace your brush bar.
Lay the vacuum on its top so that the brush bar faces you.
Using a quarter, turn the three soleplate fasteners 90 degrees to the left.
Holding the soleplate on both sides, tilt it down and away from the vacuum.
Remove the soleplate from the vacuum.
Turn down the squared tabs on the brushbar so that they face outward.
Use a screwdriver to pry the belt up from the brushbar.
While holding the belt, pull the brushbar to the left and remove it from the vacuum.
crwdns2935229:013crwdne2935229:0
crwdns2947412:016crwdne2947412:0
Too bad it don't work that easy when reassembling the drive belt over the brush roller. Dyson should reinvent another way and drop dead!
mikemo69 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Make sure you get all 4 tabs back in before you close it up. It IS a ##&&% to do on some models.
mjpotter - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What bout putting the Belt back on? Or does it Put Itself back On The Roller????
Missing Steps!
Michael - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
RE-insert brush bar? You mean insert new brush bar? (Not reinsert the old one like in the picture because after all this is instructions for replacing the brush bar right?) Aakkk!
At the bottom it says "to reassemble follow these instructions backwards"...something like that.
Excuse me I have to scream now.
Nichola - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks, I got you and I know what you meant. Thanks for taking the time to help others.
ronloveflying - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
