Dyson DC08 brush replacement
  1. Dyson DC08 brush replacement, Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement, Brush: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement, Brush: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take off the dust cannister.
    • Remove the suction hose.
  2. Dyson DC08 brush replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Extract the front filter.
  3. Dyson DC08 brush replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Extract the rear filter.
    • Unscrew the first Torx screw.
  4. Dyson DC08 brush replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Optionally, remove the rear filter cover.
  5. Dyson DC08 brush replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 2nd Torx screw.
    • Disassemble the suction hose connection (optional)
  6. Dyson DC08 brush replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the wheels.
    • The wheels clip onto the body of the appliance.
    • Unscrew the 4 Torx screws (two in the right and two on the left).
    You have to insert a flat blade screw driver between the wheel and the body of the vac cleaner for 2-3 inches to prise of the wheel.
    Gerry Stewart - crwdns2934203:0crwdne2934203:0
  7. Dyson DC08 brush replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the body of the vacuum cleaner.
    • You can use a multimeter to test the switch.
    • Disconnect the brown wire at the switch.
    • Disconnect the blue wire at the single connector by the motor.
    • Lift out the motor.
  8. Dyson DC08 brush replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the motor housing (4 clips).
    • Remover the motor from its plastic casing.
    • Disconnect the motor.
  9. Dyson DC08 brush replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • disassembly of 2 engine coals (1 Phillips screw per coal)
  10. Dyson DC08 brush replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Worn brush.
    • Opening the brush housing.
  11. Dyson DC08 brush replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Extraction of the brush and spring.
  12. Dyson DC08 brush replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the brush.
  13. Dyson DC08 brush replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson DC08 brush replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Soldering a new brush.
crwdns2935229:017crwdne2935229:0
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
christophe
crwdns2935283:007/14/12crwdne2935283:0
806 crwdns2915208:0crwdne2915208:0
crwdns2947412:016crwdne2947412:0
Very useful guide - I treated myself to a new motor as the cost was not much more than the cost of replacement brushes.
Bob - crwdns2934203:0crwdne2934203:0
Hi, where did you buy the new motor?
Nadja -
Bonjour
et si on n’a rien pour souder, y a t’il une autre solution svp?
GALLAS - crwdns2934203:0crwdne2934203:0
Bonjour ! Si vous ne disposez pas de matérial de soudure, nous vous conseillons de vous rendre à un Repair Café ou un Fab Lab. Ces associations mettent du matériel à disposition et peuvent éventuellement aussi vous conseiller sur la démarche à suivre. Bonne réparation !
Claire Miesch -
Finalement, j’ai acheté les blocs charbons.
Mais j’ai un gros problème, je n’arrive pas à refermer le boîtier plastique noir qui contient le moteur, peut-être que je replace mal le moteur…y a-t-il une astuce svp?
Merci pour votre aide..
J’ai eu le même problème.
J’avais mal orienté l’rembobineur de câble.
Et aussi l’interrupteur.
Il restait 2-3 mm de décalage coté interrupteur, en forçant avec les vis, c’est passé !
kooryel+loginwithfacebook -
super, merci beaucoup.
Je voudrais aussi changer le flexible du DC08, j’ai enlevé le support du bas, sui se fixe sur l’aspirateur, mais comment sortir le flexible de ce support svp?
J’ai beau tirer, rien ne vient…
Merci d’avance si vous pouvez m’aider
Merci pour ce tuto très bien fait.
El Barto - crwdns2934203:0crwdne2934203:0
Quelqu’un aurait les dimensions des charbons ?
Je voudrais en commander des génériques mais je viens de tout remonter !
kooryel+loginwithfacebook - crwdns2934203:0crwdne2934203:0
Pour les dimensions des charbons, je viens de redémonter :
11mm x 7mm
et en longueur
8 mm usée
30 mm neuf
Y a t’il un ressort au contact du bouton de l enrouleur car en remontant le bouton n’a plus de prise sur l enrouleur
merci
Michel - crwdns2934203:0crwdne2934203:0
Merci beaucoup pour ce tutoriel. J’ai trouvé sur Amazon les balais déjà tout montés avec leur charbon. Heureusement, car sinon j’aurais dû appendre à souder.
Brosses De Charbon Moteur avec Support Convient pour Dyson DC 08 Avec YDK https://amzn.eu/d/9upXWXE
Olivier - crwdns2934203:0crwdne2934203:0
Bon tuto.
J'ai acheté un nouveau moteur, pas cher (35€) mais de moins bonne qualité. Pas de problème, on verra combien de temps cela durera. Sinon je vais rechercher 2 charbon, le moteur d'origine fonctionnant toujours (juste problème de charbon).
Merci
titif - crwdns2934203:0crwdne2934203:0
Tutoriel très bien expliqué, merci pour le partage
Garios Kheops - crwdns2934203:0crwdne2934203:0
mine didnt work anymore. there is a, i think 'bi-metal' above the green condensator. i removed it and the thing is running. you can see the white plastic housing and the green condensator at step 9. i know it has a reason but somehow no connection anymore. just dont let it get to hot :) vairly easy machine to work on. just didnt see the screws. THNX!!!
Ramon Marees - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 133
crwdns2942667:0crwdne2942667:0 19,235
