Dyson Cinetic Big Ball Animal Upright Brushbar Replacement
  1. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement, Brushbar: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the vacuum on its back so you can see the Dyson from underneath.
  2. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Underneath the Dyson locate the red plastic tab.
    • Pull out the red tab
  3. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the brush bar and frame from the Dyson Ball.
  4. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the brushbar flat as if it was vacuuming.
    • Locate the two red tabs on either side of the brushbar frame.
    • Lift up the red tabs and the brushbar frame will come off.
  5. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the Dyson brushbar on its back.
    • Locate the four 15mm screws in each corner of the black plastic.
  6. Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson Cinetic Big Ball Animal Upright Brushbar Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 15mm screws in all four corners of the brushbar.
    • Remove the brushbar and replace it with a new brushbar.
Karla Sunjara
crwdns2935283:001/24/17crwdne2935283:0
939 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S13-G1, Banghart Winter 2017 crwdns2935289:0Cal Poly, Team S13-G1, Banghart Winter 2017crwdne2935289:0
CPSU-BANGHART-W17S13G1
okay I removed the screws the brushbar doesnt come out .. HOW do I remove the brushbar? That would be very helpful
freshveg - crwdns2934203:0crwdne2934203:0
If you look toward the center part on each side of the belt container you'll see 2 little clear tabs sticking out on each of the inner parts of the purple brush. Use a flat head screw driver and gently push each of those tabs in (obviously one side of roller then the other side) as you pull outward on the outer side of the roller (it's a 2 piece roller)
cory_duffin - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 8,659
