Dyson Cinetic Animal Ball Motor Replacement
  1. Dyson Cinetic Animal Ball Motor Replacement, Release the canister: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the gray button to release the canister.
  2. Dyson Cinetic Animal Ball Motor Replacement, Remove the canister: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the canister by lifting it out.
  3. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the base plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find and remove the four 21.5mm screws on the bottom that hold the base plate on using a T15 Torx bit.
  4. Dyson Cinetic Animal Ball Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and remove the 21mm screws for each wheel on the ball using a T15 Torx bit.
    • Remove the plastic disc.
  5. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the plastic enclosure: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and remove the five 22mm screws on each side of the ball that keep the plastic enclosure together using a T15 Torx bit.
  6. Dyson Cinetic Animal Ball Motor Replacement, Open up the plastic sphere: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom half of the plastic sphere to reveal the motor.
  7. Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully slide the motor out of its housing in the ball.
    • Cut the two wires near the side of the motor using wire cutters.
    • Install the new motor by splicing in the wires.
    • Watch this video by NJprepper321 on how to splice together wires if you are unsure on how to do this.
    • Make sure to match the wires on the motor with the correct wires in the vacuum.
crwdns2935229:05crwdne2935229:0
Alexandria Pompeii
crwdns2935283:001/25/17crwdne2935283:0
409 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-5, Banghart Winter 2017 crwdns2935289:0Cal Poly, Team 9-5, Banghart Winter 2017crwdne2935289:0
CPSU-BANGHART-W17S9G5
crwdns2935297:018crwdne2935297:0
Basic but correct only mine has spade connectors on the motor so no need to cut and solder wires. The problem I found was that the main inner filter was blocked, probably by cement dust who I am guilty of! I would like to know if this is available as a spare part? I have cleaned it for now but it really needs changing.
Tim - crwdns2934203:0crwdne2934203:0
This vacuum cleaner is based on the DC52 model. The post motor HEPA filter has the part number 922444-02 and is offered by many spart part vendors in the web. Just google Dyson 922444-02. I have made an instruction on how to replare or clean it.
HowThingsWork -
very good instructions, dismantled perfectly.
Allain Ouellette - crwdns2934203:0crwdne2934203:0
great instructions, dismantled perfectly.
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 201
crwdns2942667:0crwdne2942667:0 25,202
