crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Press the red release button and pull the canister up and away.
Locate the red dial at the back of the wand and turn counterclockwise to detach the wand.
Remove the four 15mm screws behind the power button using a Torx T15 screwdriver.
Use a spudger to push the two clamp tabs behind the power button towards the middle of the vacuum.
Detach the power box case from the body of the Dyson after both clamps have been pushed out.
Upon removal of this case, you will be able to see a red circular power button.
Gently pull the power button out of its slot as shown.
Detach the power button box from the two wires connecting it, and replace the faulty power button box with a functional one. The power button is the first black one.
