Dyson Ball Animal Hose Replacement
  1. Dyson Ball Animal Hose Replacement, Hose: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson Ball Animal Hose Replacement, Hose: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off power and unplug the vacuum, then turn the vacuum to look at the hose.
  2. Dyson Ball Animal Hose Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dyson Ball Animal Hose Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the red dial counterclockwise and pull up on the wand to remove.
  3. Dyson Ball Animal Hose Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson Ball Animal Hose Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson Ball Animal Hose Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press in the red button where the wand attaches to the hose and pull apart.
  4. Dyson Ball Animal Hose Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the main canister by pressing the red release button and pulling up and away.
  5. Dyson Ball Animal Hose Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dyson Ball Animal Hose Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dyson Ball Animal Hose Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the base of the hose so your thumb reaches around to press the red tab shown.
    • Push the red tab at towards the hose while pulling the hose upwards.
    • With some wiggling, it will come out.
    The dyson up20 does not have a clip on the hose. You have to turn the base of the hose counterclockwise to remove and clockwise to install.
    Joshua Schlesner - crwdns2934203:0crwdne2934203:0
    I have the dyson cinematic animal ball, and I cannot get the hose to release also, I tried the red tab, tried twisting etc nothing works
    Greg Papatrefon - crwdns2934203:0crwdne2934203:0
    I used a pair of needle nose pliers to hold the red tab pulling up and toward the hose
    Margaret Johnson -
    No suction from wand assembly even when hose taken off, all openings checked, all filters cleaned x7 years. I have had this vacuum for about 7 years- it’s barely used because 6 1/2 of those years it doesn’t bloody work. Never buying a Dyson ever again. After 3 months of owning it I bought another vacuum because there is ALWAYS something wrong with it. The hose part hasn't worked since the third month of owning it. It rarely stands up. It won’t switch suction from bottom to hose. Oh yes lots of suction! But that does you a fat lot of good when it does not suck out the wand or the bottom.
    Margaret Johnson - crwdns2934203:0crwdne2934203:0
    Red tab broke off while installing hose now what?
    Mike - crwdns2934203:0crwdne2934203:0
    The red tab broke off hose after I got it installed now what?
crwdns2935229:015crwdne2935229:0
Mitchell Klein
crwdns2935283:004/23/17crwdne2935283:0
911 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G5, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S15-G5, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S15G5
crwdns2935297:017crwdne2935297:0
crwdns2947412:09crwdne2947412:0
I used the hose and attachments on my ball animal + up13 and after removal of attachment and stowing the hose to the handle assy. , I can not get the vacumm to stop sucking from the top of the handle? I’ve attempted reading the owners manual (which is not user friendly) and also watched Youtube demonstrations with no luck. This has been two days of struggling with no success???
james gaspard - crwdns2934203:0crwdne2934203:0
The suction is diverted to the hose when the machine is upright. Stand behind the machine, pull the handle towards you and the transfer valve automatically diverts the suction to the brush head. Put it back into the upright position and suction automatically diverts to the rear hose.
mike.vardy - crwdns2934203:0crwdne2934203:0
can anyone show me a picture of the transfer valve? I think it is not going into position when I try to use the wand.
Rita & Chuck Mergen - crwdns2934203:0crwdne2934203:0
it looks like the wand has a round plastic device in middle is this correct? i have taken the wand out of the hose and the hose has suction but when all goes back together and turn on the hand held wand device has no suction
woody jones - crwdns2934203:0crwdne2934203:0
Awesome! Worked like a charm. I had sucked up one of the cat's toys. I was able to remove the little toy and the hose works again.
Thank you!
jboyd5322 - crwdns2934203:0crwdne2934203:0
When my vacuum is upright the transfer of suction does not happen to the hose - I think something is missing between the hose to the ball and the hose to the handle…….I will just take it in - thank you for the tutorial - someone sucked up a mask so that started the problem………
kimnto - crwdns2934203:0crwdne2934203:0
My hose has holes beneath the ball, how do you replace that hose?
Lucy - crwdns2934203:0crwdne2934203:0
Thank you!! I had a couple coins stuck in the wand and this showed me perfectly how to access them and clear the blockage. MUCH appreciated!!🙏🏾
Michelle Cargill - crwdns2934203:0crwdne2934203:0
Excellent and clear instructions. I’d mistakenly tried to find a solution through YouTube and wasted so much time. I was at the point of replacing my appliance until I found the right instructions here. Even Dyson couldn’t be bothered to provide a solution.
A Hob - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 110
crwdns2936753:030crwdne2936753:0 541
crwdns2942667:0crwdne2942667:0 140,411
