The WiFi antenna is found on the back left of the device. It is black and extends an inch outside of the device. This guide will take you through the steps of removing the cover and antenna. The antenna must be removed to perform maintenance on the motherboard of this device.
Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
Remove the two 5mm screws on the left and right side panels.
Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
Use the metal spudger to remove the white clip from the antenna by prying the clip away from the antenna.
Remove the two 7mm screws from both sides of the antenna.
Slide the antenna inwards and gently remove.
