Dymo LabelManager 160 -Not printing. Spring tensioner detached - Repair.
  1. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the device face-down to access the battery compartment.
  2. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
  3. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To open the cartridge compartment, simply lift on the front of the device.
  4. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
  5. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
  6. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair.: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair.: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the rubber keyboard from the device.
  7. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Remove/loosen the PCB: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Remove/loosen the PCB: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We need to remove the main circuit board. This needs to be approached with care.
    • The first photo indicates the three obvious screws. These would be easy to remove.
    • However, there is a another screw beneath the screen.
    • With a plastic spudger gently prise the screen up at the top edge, it is held in place by two foam sticky pads and tape. You may find a small amount of gentle heat will help release the glue, but be very careful to neither crack the screen nor damage the ribbon connector.
    • with the screen flipped forward onto the keyboard PCB, you can now remove the hidden screw indicated in the second photo.
    • You should now have enough movement in the PCB to remove the remaining screws in the plastic body beneath (see next step for details)
  8. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Remove the inner frame - carefully: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Remove the inner frame - carefully: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Remove the inner frame - carefully: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take lots of photos!
    • I called this the frame because it literally holds everything in place. As you lift this there are a number of small parts that will try to escape/move/hide. You have been warned.
    • Before we get there, we need to remove 3 more screws.
    • one is hidden almost centrally to the main body, but there should be enough length in the ribbon cable to allow access. If you can't get to it, try releasing the power port (shown floating free in the photo) and you ought to be fine.
    • Another is on the left hand edge and was previously concealed by the PCB.
    • The last one is down the bottom end near the batteries and should pose no problems at all.
    • Now, carefully lift the frame and PCB away. In the photos, you can see a blue circled wheel; this is one example of a component that is supported by the frame we are removing. Make a note of things that might escape, such as the spring clip.
  9. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Notes about the mechanism: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Notes about the mechanism: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Notes about the mechanism: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you are lucky, this part may be skipped.
    • As you lift the frame you may find that the stainless steel rods that act as axles/pivots to the levers and cogs come along for the ride. Take note, you will need to reverse this later, and the jigsaw puzzle is easier if you have a reference.
    • You will need to pay careful attention to the pieces, in particular the hooked "cam follower" lever (green rectangle) which you'll need to ensure is correctly positioned once the spring (see next step) has been reattached.
    • Once you can get to the small lever shown with the yellow circle, you are ready to start the actual repair.
  10. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., inspect the damaged part.: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., inspect the damaged part.: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., inspect the damaged part.: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The source of our problem lies in the two yellow highlights.
    • The rectangle highlights the underside of the hinge well of the ribbon cover door. You should be able to see a small spring through the hole.
    • That spring should be attached through the "eye" highlighted by the yellow circle. Unfortunately this seems to wear through with friction and causes our fault.
    • Repair the split as best you can. I have been able to get away with a drop of super-glue; you may find that you need to melt it together if the split is slightly larger.
  11. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Now for the fiddly spring.: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair., Now for the fiddly spring.: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We need to retrieve the spring. Once again, this is simple but don't rush or you'll scatter more parts everywhere.
    • I found it easiest to remove the spring from the door. This does involve flipping over the shell, hence the additional warning to watch for loose parts.
    • The door hinge is a small plastic nub in the shell that locates into a large hole in the door (see red circle), a little leverage with a spudge should free it.
    • The spring is retained by a sturdy stainless pin (Shame that the other end was not so well thought out.) poke the end of the pin free enough to slide the spring loose.
    • You can now attach the spring to the repaired lever by hooking the open spring end through.
    • Finally, you need to offer the spring back through through the hole in the case and with a pair of tweezers or a hooked spudger, pull it back onto the metal pin
    • push the pin back home to lock it all in place.
    • slot the cover back over the hinge nub.
  12. Dymo LabelManager 160  -Not printing. Spring tensioner detached - Repair.: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reassemble your device, you follow these instructions in reverse order, it is important to note that you should check that the mechanical parts are properly aligned with each step.
    • In particular, the "cam follower" lever must be placed under tension when the cartridge door is closed and the spring is taught. This causes the print head to lift. It was the lack of lift on the print head that was causing the issue before.
    • With luck you are now ready to print again.
Following these steps in reverse, using all the photos that you took, (you did take them right?) to get the moving parts in the right places, you should be able to reassemble the device relatively easily. A final check is similar to the initial diagnosis. Open and close the cartridge door and you should see the print head lift and fall if the spring is doing the intended job.
Neil Horlock
crwdns2935283:011/19/19crwdne2935283:0
272 crwdns2915208:0crwdne2915208:0
Thank you for this guide. During my research into the repair I found that the author of this repair video also provides a link to a design for a replacement part that can be 3d-printed. So far it is holding up well for me.
notbrokeyet - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 81
crwdns2942667:0crwdne2942667:0 1,220
