Dymo DiscPainter Turntable Belt Replacement
  1. Dymo DiscPainter Turntable Belt Replacement, Remove Lid: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dymo DiscPainter Turntable Belt Replacement, Remove Lid: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dymo DiscPainter Turntable Belt Replacement, Remove Lid: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press inward on the hinge (as arrow, on the thinner side) to disconnect this side of the lid.
    • The opposite side of the lid will now be free to fully remove.
  2. Dymo DiscPainter Turntable Belt Replacement, Separate Upper Chassis: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dymo DiscPainter Turntable Belt Replacement, Separate Upper Chassis: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 6 Philips #2 screws that secure the upper chassis to the lower chassis.
    • The upper and lower chassis should simply lift apart.
    • Disconnect the two printhead ribbon cables (careful to keep them in that layered order when reassembling!) and the sensor connectors, which simply lift out.
    • If your print bed is not in the fully-forward position, and the lid is locked: there are two spring-loaded manual release levers on the bottom edge of the printer. Simultaneously slide them towards the front of the printer while lifting the lid (requires 2-1/2 hands) to override the lock and free the lid to open the chassis.
  3. Dymo DiscPainter Turntable Belt Replacement, Separate print bed from lower chassis: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dymo DiscPainter Turntable Belt Replacement, Separate print bed from lower chassis: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dymo DiscPainter Turntable Belt Replacement, Separate print bed from lower chassis: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pop out the C-clip in the rear of the machine, attaching the rail to the motor mount.
    • If your print bed is too far forward to access the front C-clip, you can freely twiddle the spiral rod to move the print bed further to the rear. It is automatically calibrated on every startup, so there is no harm in moving any motor manually.
    • Pop out the C-clip in the front of the machine on the opposite rail, attaching the rail to the chassis.
    • C-clips are hateful little things and love to fly. A great tool to have on hand is a magnetic, small-blade flat screwdriver, both for disassembly and reassembly. When disassembling, use another hand to cover any potential fly-off path the clip may take if it tries to escape Earth.
    • Once the C-clips are removed, simply slide each rail in the direction that was freed by the C-clip, and it should dislodge the opposite end, which allows you to pivot the rod and completely remove the rod.
    • Tilt the print bed mechanism on its side, revealing the ribbon connector to the main board.
    • To unlock the ribbon connector on the board, slide the locking tabs towards the back, parallel to the board, at the same time. They should move approximately 1-2mm, and the ribbon cable should then move freely within the socket, requiring no force to remove it, as it is a zero insertion force (ZIF) connection.
  4. Dymo DiscPainter Turntable Belt Replacement, Disassemble the print bed & replace belt: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dymo DiscPainter Turntable Belt Replacement, Disassemble the print bed & replace belt: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dymo DiscPainter Turntable Belt Replacement, Disassemble the print bed & replace belt: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 6 Philips #2 screws that secure the lower print bed to the upper cover.
    • When reinserting screws into plastic threads, it's advisable to first turn the screw counterclockwise until it drops into the pre-formed thread. This "click" indicates the correct alignment, allowing you to then screw it in clockwise without cutting new threads, which could potentially strip the plastic and damage the hole.
    • The turntable belt can now be accessed for cleanup and replacement.
    • There is a sensitive position-sensing optical ring on the underside of the turntable. Be sure not to damage it with any scraping or fingerprints.
Matt Falcon
crwdns2935283:005/09/15crwdne2935283:0
2.677 crwdns2915208:0crwdne2915208:0
What sort of belt is used to replace the OEM belt?
SQUANON DORF - crwdns2934203:0crwdne2934203:0
I initially replaced the OEM belt with a regular office rubber band. It worked fine for printing, but it deteriorated and broke by the end of the year. So, when I rebuilt it, I documented the process for this guide.
The motor itself is just a basic DC motor and doesn’t directly control the disc position. Instead, there's an optical encoder around the base of the turntable that handles position sensing and synchronization. As a result, the belt only handles spinning the turntable and has no impact on print accuracy or quality because the encoder ensures everything is aligned on the driven side of the belt.
Long story short: use any belt that fits, spins freely, and doesn't pull too tight. Preferably one that won't decompose back to oil in the next decade or so (so you never have to do this again). On this rebuild, I just grabbed an appropriate-sized belt out of a belt assortment I got off Amzn. Seems the only way to get belts these days.
Matt Falcon -
crwdns2942667:0crwdne2942667:0 122
