Durofix RV332 Motor Replacement
  1. Durofix RV332 Motor Replacement, Screwdriver Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove six 13 mm screws from the casing.
    • Place the screws in a small container so they don’t get lost.
  2. Durofix RV332 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Durofix RV332 Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic separating tool (or a prying tool) to gently pry apart the top and bottom halves of the driver’s plastic housing.
    • Work slowly around the edges to avoid cracking the plastic or damaging internal clips.
  3. Durofix RV332 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Durofix RV332 Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the casing is open, lift out the printed circuit board (PCB), battery, LED, and existing motor assembly as one unit from inside the housing.
    • Using wire cutters, cut the black and red motor wires where they connect to the motor. (You’ll later re-solder to the new motor.)
  4. Durofix RV332 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Strip about ¼ inch (≈ 6 mm) of insulation off the ends of both red and black wires.
    • Make sure the exposed wire is clean (unoxidized) and ready to solder.
  5. Durofix RV332 Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Durofix RV332 Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Durofix RV332 Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before soldering, check that the contacts on the new motor are clean and free from residue.
    • Solder the red wire to the motor’s positive terminal (usually marked with a “+” or a red circle).
    • Solder the black wire to the motor’s negative terminal (or the remaining terminal).
    • Allow the solder joints and motor to cool down fully before proceeding.
    • Solder carefully! Using a hot soldering tool may result in injury!
  6. Durofix RV332 Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the motor, along with the PCB, LED, and battery, back into the plastic housing in the correct orientation.
    • Close the casing halves together, ensuring clips and alignment are correct.
    • Reinsert and tighten the six screws you removed earlier.
    • Finally, test the device to confirm the motor now works.
    • If everything functions, you're done. If not, reopen and re-check your soldering and connections.
Tyler Vincent
crwdns2935283:002/24/14crwdne2935283:0
503 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 5-5, Lauer Spring 2014 crwdns2935289:0Michigan Tech, Team 5-5, Lauer Spring 2014crwdne2935289:0
MTU-LAUER-S14S5G5
Too late finding this (although self-explanatory). I was wondering when I tried this - WHERE does one find the spare component motor to replace? I searched the internet, but for something so specific, I just couldn't locate the right channels. For future reference, is there a typical store of small motors, etc... to locate these things?
Arkadiusz - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,019
