Ducky One 3 SF Keycaps and Switches Replacement
  1. Ducky One 3 SF Keycaps and Switches Replacement, Keycaps and Switches: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ducky One 3 SF Keycaps and Switches Replacement, Keycaps and Switches: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable from your keyboard.
    • Place the keyboard on a flat and stable surface.
  2. Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the switch puller to remove the keycap from the keyboard.
    • Remove all of the keycaps you need to replace or clean.
  3. Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the keycaps in a container.
  4. Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a key switch puller to secure the switch at the top and bottom.
    • Pull the switch away from the keyboard.
    • Ensure the switch puller is positioned and secured between the switch and the keyboard to prevent any damage to the switch.
  5. Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place all of the switches from the keyboard in a container.
  6. Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a dust blower to remove loose debris from your keyboard.
    • Use a foam tipped swab and Isopropyl Alcohol to clean any residue, oils, or grime from the keyboard.
    • Make sure the keyboard is completely dry before replacing the switches and keycaps.
  7. Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Soak the keycaps in soapy water.
    • Remove all dirt or debris from each keycap.
  8. Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let the keycaps sit for 10-20 minutes to disinfect.
    • Rinse the keycaps with water.
    • Place them on a towel and use a cloth to remove excess water.
    • Leave the keycaps to air dry.
    • Ensure that the keycaps are completely dry before proceeding to the next step.
  9. Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the new switch into the corresponding holes in the keyboard and push the switch into position.
    • Make sure that the switch pins line up correctly with the holes on the keyboard so they don't get bent or damaged.
    • Continue the process until all switches are in place.
  10. Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ducky One 3 SF Keycaps and Switches Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace each keycap in the correct position and press onto the key switch.
    • Use the following website to confirm both the correct positioning and functionality of the keycap.
Hopefully these steps were clear and useful to you!
Tony Lee
crwdns2935283:001/10/24crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
York University, Team 2-18, O'Regan Winter 2024 crwdns2935289:0York University, Team 2-18, O'Regan Winter 2024crwdne2935289:0
YORK-O'REGAN-W24S2G18
crwdns2942667:0crwdne2942667:0 457
