crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓This guide will show the reader how to remove and replace the rumble motors for a DualShock 4 controller.
DualShock 4 Controller Motherboard and Midframe Assembly (JDM-055)$44.995crwdns2942747:0crwdne2942747:0
DualShock 4 Controller Motherboard and Midframe Assembly (JDM-050)$34.99crwdns2942747:0crwdne2942747:0
DualShock 4 Controller Motherboard and Midframe Assembly (JDM-040)$34.99crwdns2942747:0crwdne2942747:0
DualShock 4 Controller Motherboard and Midframe Assembly (JDM-030)$29.995crwdns2942747:0crwdne2942747:0
Remove the four 2mm screws on the rear plate using the #000 Phillips screwdriver.
Desolder the joints that attach the rumble motors to the motherboard.
There is a hidden screw underneath the battery pack that attaches the faceplate to the motherboard.
Lift the pack and remove the 10mm screw using the #000 Phillips screwdriver.
Remove the faceplate from the motherboard.
With some added pressure, push down and outward in order to free and remove the rumble motors from their socket.
crwdns2935229:014crwdne2935229:0
I’d recommend adding removal instructions for the touchpad also
AlexMorse - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
the rumble packs are stuck with an adhesive on my controller. The best way to remove the rumble pack in this case? thanks
Ka Erd - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I'm most likely way too late, but if there is an adhesive, I would probably use something that breaks glue down and is safe for electronics
Harry Harshman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
