DualShock 4 CUH-ZCT1 Charging Port Replacement
  1. DualShock 4 CUH-ZCT1 Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Dualshock 4 controller on its back, and use a Phillips #00 screwdriver to remove the four 6 mm screws.
  2. DualShock 4 CUH-ZCT1 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lift the backplate onto the front side of the controller making sure not to fully remove the backplate.
  3. DualShock 4 CUH-ZCT1 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CUH-ZCT1 Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ribbon cable from the motherboard of the controller and place the top half of the controller on the side for later.
  4. DualShock 4 CUH-ZCT1 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the light bar's sub-assembly by gently lifting up the piece.
  5. DualShock 4 CUH-ZCT1 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the clear plastic piece out of the controller by pulling into the controller and removing it.
  6. DualShock 4 CUH-ZCT1 Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6 mm Phillips screws that are on top of the PCB of the charging port.
  7. DualShock 4 CUH-ZCT1 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CUH-ZCT1 Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently wiggle the charging port's PCB side to side until it detaches from the controller.
    el mando dice que no tienen carga, arranca y se apaga
    Joaquin Guerra - crwdns2934203:0crwdne2934203:0
crwdns2935229:08crwdne2935229:0
Andy Lam
crwdns2935283:001/31/23crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
One thing I thought I'd leave here is in-case you wanted to upgrade to USB-C at the same time, this is an aftermarket product that can let you do that - https://www.tindie.com/products/mariushe...
Works an absolute treat, and the quality is astoundingly good :D
Aadi Bhamidipati - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 95
crwdns2936753:030crwdne2936753:0 349
crwdns2942667:0crwdne2942667:0 7,960
