The charging port is a common issue that comes with the Dualshock 4 controller as it could be worn overtime. In this guide, we will go through the steps on how to make a simple and easy repair on the Dualshock 4 CUH-ZCT1's charging port.
Flip the Dualshock 4 controller on its back, and use a Phillips #00 screwdriver to remove the four 6 mm screws.
Slowly lift the backplate onto the front side of the controller making sure not to fully remove the backplate.
Remove the ribbon cable from the motherboard of the controller and place the top half of the controller on the side for later.
Remove the light bar's sub-assembly by gently lifting up the piece.
Lift the clear plastic piece out of the controller by pulling into the controller and removing it.
Remove the two 6 mm Phillips screws that are on top of the PCB of the charging port.
Gently wiggle the charging port's PCB side to side until it detaches from the controller.
crwdns2935229:08crwdne2935229:0
One thing I thought I'd leave here is in-case you wanted to upgrade to USB-C at the same time, this is an aftermarket product that can let you do that - https://www.tindie.com/products/mariushe...
Works an absolute treat, and the quality is astoundingly good :D
muito bom esse tutorial
