DualShock 4 CHU-ZCT2U Charging Port Replacement
  1. DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
  3. DualShock 4 CHU-ZCT2U Charging Port Replacement, Charging Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Charging Port Replacement, Charging Port: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the ribbon cable from the charge port, using a set of tweezers.
  4. DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the right hand corner of the opaque white piece with a pair of tweezers, and pull it upwards to remove it.
  5. DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the clear plastic piece up by its right hand corner.
    • Pull it to the right to remove the bottom left hand corner from the groove.
    • Remove the clear plastic piece. It pushes in easily.
  6. DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Charging Port Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the black sticker on the charge port, using a pair of tweezers.
    • Unscrew the 4.50mm screw in the center of the port chip, using a Phillips-Head screwdriver.
    • Pull the charging port out with a pair of tweezers.
crwdns2935229:016crwdne2935229:0
David Seale
crwdns2935283:010/09/17crwdne2935283:0
1.718 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G5, Leahy Fall 2017 crwdns2935289:0USF Tampa, Team S1-G5, Leahy Fall 2017crwdne2935289:0
USFT-LEAHY-F17S1G5
crwdns2935297:028crwdne2935297:0
crwdns2947412:09crwdne2947412:0
Came in handy, since it’s hard enough to fix a JDM-030. Thanks!
Sunset Shimmer - crwdns2934203:0crwdne2934203:0
Just did this on my JDM-030 (3rd generation DS4) as well. I would point out that the charge port for the JDM-030 (JDS-030?) looks slightly different and has more of a T-shape than the JDS-040, but aside from that, the instructions are functionally the same.
I will lastly add that having good tweezers is a must: the tweezers my jeweler’s drivers came with were crap and I had to go to the store to buy another pair. Make sure your equipment is solid before assembly.
Rob Barba - crwdns2934203:0crwdne2934203:0
Can The JDS 040 work in a controller that uses the JDS 030?
RandyH - crwdns2934203:0crwdne2934203:0
Tried to replace my usb port with a board that reads “1-981-33-31” from amazon. It was listed as JDS-40 and it does not work. In fact when plugged into a usb port on my laptop the ribbon cable gets noticeably hot but the controller will not power on.
Devin Sidell - crwdns2934203:0crwdne2934203:0
Got the same problem. Any idea?
Jacco Veldscholten -
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 13,352
