DualShock 3 Front Shell Cover Replacement
  1. DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the controller over and locate the five 7.2mm Phillips #0 screws securing the rear cover to the front cover.
  2. DualShock 3 Front Shell Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualShock 3 Front Shell Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualShock 3 Front Shell Cover Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the five screws holding the rear/back cover in place.
  3. DualShock 3 Front Shell Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 3 Front Shell Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the rear cover away from the rest of the controller starting from the bottom side adjacent to the analog stick controllers.
    • Push gently by sliding the rear back forward towards the top edge of the dual shock controller to prevent tripping the two bottom triggers labelled (2).
  4. DualShock 3 Front Shell Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the rear cover off of the controller to expose the interior.
  5. DualShock 3 Front Shell Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualShock 3 Front Shell Cover Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualShock 3 Front Shell Cover Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully detach or disconnect the lithium polymer battery from the motherboard.
    • The wires are fragile, be careful not to break them when pulling out the battery as they can break easily.
  6. DualShock 3 Front Shell Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualShock 3 Front Shell Cover Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualShock 3 Front Shell Cover Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove five 7.2 mm screws from the motherboard.
    • Lift the motherboard, vibration motors and analog module joysticks pads all in one connection, away from the shell.
  7. DualShock 3 Front Shell Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 3 Front Shell Cover Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the rubber or plastic part holding the button triggers labelled (2) in place.
    • Be careful not to strip the plastic rubber holding the triggers in place.
    • Slide the trigger button retainers away from the front shell. Set them aside.
  8. DualShock 3 Front Shell Cover Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set aside the colored buttons and lift the white rubber part holding the Dpad buttons in place to securely remove it.
Joseph Wambui
crwdns2935283:007/09/21crwdne2935283:0
253 crwdns2915208:0crwdne2915208:0
York University, Team 1-28, O'Regan Fall 2021 crwdns2935289:0York University, Team 1-28, O'Regan Fall 2021crwdne2935289:0
YORK-O'REGAN-F21S1G28
Personally I believe with the current price of a DualShock 3 controller its not even worth it to replace the following parts. Or maybe its just me? Sony has done a great product and will continue to do so!
Andrew McMason - crwdns2934203:0crwdne2934203:0
The original 6 axis controller I got with my PS3 back in the day has different size screws than the gold plated one I got a few years later. They're about 3 mm longer too
Gregory Hedges - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 143
crwdns2942667:0crwdne2942667:0 5,168
