DualShock 3 Buttons Replacement
crwdns2869540:0crwdne2869540:0: 175K
12
121
545
175,321
crwdns2955950:0crwdne2955950:0: 36
crwdns2960004:030crwdne2960004:0, crwdns2960008:06crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 111
crwdns2959974:0111crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 79
crwdns2959982:079crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 15 - 30 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Use this guide to replace the plastic button covers and the rubber button contacts on any DualShock 3 controller.
    1. DualShock 3 Buttons Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
    2. DualShock 3 Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
    3. DualShock 3 Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 3 Buttons Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
      • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
      • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
    1. DualShock 3 Buttons Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the battery off the motherboard for enough clearance to access the battery connector.
    2. DualShock 3 Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pull the battery connector away from its socket on the motherboard.
      • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
    1. DualShock 3 Buttons Replacement, Motherboard Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
    2. DualShock 3 Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualShock 3 Buttons Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualShock 3 Buttons Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the trigger button retainers slightly away from the front cover.
      • Remove the #1 button on both sides.
    3. DualShock 3 Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 3 Buttons Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
    4. DualShock 3 Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the motherboard assembly from the front cover.
      • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
    1. DualShock 3 Buttons Replacement, Buttons: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 3 Buttons Replacement, Buttons: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the rubber button contacts off the front controller cover to access the plastic button covers.
      • Lift any damaged plastic button covers out of the controller cover.
    2. DualShock 3 Buttons Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The D-pad has a three-armed plastic piece that must be installed as shown before installing the rubber button pad for it to work properly.
crwdns2935229:0111crwdne2935229:0
My Dualshock 3 didn't have the three armed plastic piece on the D-pad. Mine's a red one, relatively recent. My controller also had the problem where it would randomly send button press events when using the L-stick. I traced the problem to the ribbon connector between the board and the contacts, which was very dirty. I cleaned the contacts and put the controller back together with an additional rubber shim between the back cover and the battery, which got rid of the creakiness of the somewhat loose-fitting case. Works great now.
Kevin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How do you clean the contacts? Is there a special way?
yeshuabendavid - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks. ^^ Tightened screws after opening it and this kind of problem got solved.
Janne K - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Are these instructions the same for the dual-shock 2?
Larry Howard - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
TNX-could not really figure out where the 3-armed plastic should fit in but tnx to step 11 i know-now im going to dismantle my controller again.
Kristian Brandström - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 121
crwdns2936753:030crwdne2936753:0 545
crwdns2959996:0crwdne2959996:0 175,321
