Use this guide to replace the internal lithium battery inside PlayStation 3 controllers.
Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
Lift the battery off the motherboard for enough clearance to access the battery connector.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Carefully pull the battery connector away from its socket on the motherboard.
crwdns2935229:0163crwdne2935229:0
crwdns2947412:020crwdne2947412:0
I got the shell separated but unfortunately snapped the lil plastic clip on the rear of the controller's bottom half. a lil super glue and treezers fixed tht up nicely...Thanks for the help
KUDOS to you!!!
Rob (rjmat42)
I have different battery on my second controller, battery itself have pins to connect it with board, no more white plastic holder :/
Try Amazon Cody
whats is amazon cody?
Anyone have any idea where I can find the plastic retainers for the battery? I bought the new one, but my old battery has the clips attached. I don't want this thing just jiggling around in there, it'll drive me nuts.
Thanks.
