DualShock 2 Disassembly
  1. DualShock 2 Disassembly, DualShock 2 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 2 Disassembly, DualShock 2 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First, check that the connection port of your controller (whether wireless or not) has all the pins.
    • If you have a wired controller (a controller with a cable that connects directly to your console) try bending it in different directions. This may recconect broken connections within the controller cabel and could be a temporary fix.
    If it's missing a pin, then what do you do?
    Terry Lopez - crwdns2934203:0crwdne2934203:0
    Some models of the DualShock2 controllers could be missing the pin circled in the picture. After doing some online searching, I found the pin slot circled in the picture is the connector for a white wire, which is listed as unused for some controller models. -So if your controller is only missing that one, and the other 8 pins are in their place (and straight) you should be fine. However if you believe you are missing a pin. I really don't see a way you could replace the individual pins with out breaking the case for the entire connector port. I would buy a new one at that point, maybe keep the old controller for its guts. (assuming the only problem is the pins)
    stevon shaw - crwdns2934203:0crwdne2934203:0
    THANKS stevon i was looking for this
    aswin P Kumar - crwdns2934203:0crwdne2934203:0
    What if one of the pins are bent?
    Adam Bolyard - crwdns2934203:0crwdne2934203:0
    When looking into the port with the arrow up, that second pin from the right is not always there and it should be fine. that one out of the nine pins is optional and only used for certain peripheral like light guns, newer model controllers come from the factory without that pin.
    berzerkeror - crwdns2934203:0crwdne2934203:0
  2. DualShock 2 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 2 Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip Over Controller and remove all 6 screws from the bottom of the controller.
  3. DualShock 2 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 2 Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screws are removed, carefully pry the controller open with your hands.
    • Remove the screw holding the circuit board in place.
  4. DualShock 2 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the circuit board from the front cover of the controller.
    There's this green flat wire that's keeping it from disconnecting so I need to know how to make it disconnect and reconnect
    SirDarkClover - crwdns2934203:0crwdne2934203:0
  5. DualShock 2 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Analyze the rubber pads for any debris that may be getting in the way of the black pads. These make an electrical connection on the pad and may not be contacting properly.
  6. DualShock 2 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Examine the flexible trigger board itself for any dirt or debris that could get in the rubber button pad's way.
  7. DualShock 2 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check the connection of the flexible trigger board to the main circuit board of your controller.
  8. DualShock 2 Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the previous steps are all covered and you are still facing difficulties in getting your buttons to work, consider replacing the main circuit board or flexible trigger board.
  9. DualShock 2 Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reverse the disassembly steps until the controller is back to its original state. Plug the controller into the console and test whether the fix worked.
crwdns2935229:047crwdne2935229:0
Peder Hertel
crwdns2935283:009/29/15crwdne2935283:0
1 474 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-5, Green Fall 2015 crwdns2935289:0Cal Poly, Team 17-5, Green Fall 2015crwdne2935289:0
CPSU-GREEN-F15S17G5
crwdns2947412:07crwdne2947412:0
Dualshock 2 controllers, model A and H, are having 8 pins, not 9. Your first Step is false and rarely wires are the cause of the problem.
Eva Langley - crwdns2934203:0crwdne2934203:0
No my Dual-shock 2 controller has 9 pins so you are wrong he is right man.
Adam Bolyard -
Eva Langley is correct, some of these controllers have only 8 pins, not 9. I myself can conformed this because I just recently opened one of two brand new fresh out of the box Sony original equipment controllers that I purchased (for a little less than $10 a piece) during a clearance sale at my local Sears just before they went out of business. So Eva is NOT wrong. I still have the second one still in the box and before anyone ask, I don’t won’t to sale. I purchased them because I have had both my original controllers go out after they were sitting up for a few years without use. My game units are very well taken care of but the controllers of the PS2 just stopped working and finding a definitive answer to why this happens is STILL very elusive in 2019.
byordsilp -
After opening one of these, the R2 and L2 buttons don't feel right, is there a way to fix this?
Fridtjof Riibe - crwdns2934203:0crwdne2934203:0
Try to put R2 and L2 after you close the shell. The buttons have clips that hold on position after you insert them .
Alex SC -
Does anyone know where to get parts? Sticks, and microswitches for L3 and R3?
leafybye - crwdns2934203:0crwdne2934203:0
Are the pins you are seeing from different models of Dualshock? Dualshock original is different maybe.
DualShock Controller (SCPH-110) (original playstation)
DualShock 2 Analog Controller (SCPH-10010)
crwdns2936751:024crwdne2936751:0 21
crwdns2936753:07crwdne2936753:0 168
crwdns2936753:030crwdne2936753:0 737
crwdns2942667:0crwdne2942667:0 75,172
