This guide details how to replace the battery in a DualSense Edge PlayStation 5 controller. If your controller won't power on or is draining quickly, follow this guide for battery replacement.
A functional battery provides power to your controller. Unfortunately, all batteries will drain after going through a repeated amount of charge cycles. If you notice that your charged battery is draining more quickly than usual or, even worse, has ceased to hold a charge at all, you should replace your battery.
If your battery is swollen, take extra care and handle it with caution.
Make sure the controller is turned off before you begin.
Use the opening pick to push the release latch on the back of the controller.
Raise both left and right levers next to each stick module.
Slide both stick modules out of their slots.
Use the pick to pop both the R1 and L1 shoulder buttons out.
Slide the opening pick along the left and right sides of the rear trim to release the clips that secure the trim.
Turn the controller around and continue sliding the opening pick along the trim to release the remaining clips.
Remove the rear trim now that all clips are released.
Remove the two 6.4 mm‑long screws from the L1 and R1 button enclosures (one screw on each side).
Pull the lever to the left and lift up to detach it from the controller.
Be careful with the tiny spring attached to the lever, as it is easy to lose once detached.
No mention of removing the two additional screws under the spring?
Remove the nine screws securing the rear case:
Seven 6.4 mm‑long screws
Two 10.5 mm‑long screws
Insert an opening pick between the front and rear casing and gently pry them apart.
Use your hands to pull the rear case off of the controller carefully.
Use a pair of tweezers or your fingers to lift the cover from the controller.
Slide the flat end of the cover under the plastic tab in the rear case.
Use your opening pick to lift the battery from its enclosure and expose the wire connection.
Place your opening pick under the low profile connector and pull it upward toward you to disconnect the battery.
where can i buy battery replacement
取替の説明が有っても、バッテリー自体が手に入らないから日本では上げても余り意味が無い。
Yeah that’s great and all but without a battery all I can really do is kick rocks so what’s a guy gotta do to get a new one of those? Preferably with increased capacity but I’ll take an original new one too.
