Dual BT 10 Mainboard Disassembly
  1. Dual BT 10 Mainboard Disassembly, Removing bottom screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dual BT 10 Mainboard Disassembly, Removing bottom screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dual BT 10 Mainboard Disassembly, Removing bottom screws: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the device if needed and put the power switch into the "OFF" position.
    • Turn the device upside down
    • Remove the two foam feet at the front end of the speaker (the end with the buttons)
    • Unscrew the two screws revealed by the foam pads
  2. Dual BT 10 Mainboard Disassembly, Removing the top screw: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dual BT 10 Mainboard Disassembly, Removing the top screw: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dual BT 10 Mainboard Disassembly, Removing the top screw: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device in its normal position (standing on the foam feet)
    • Remove the screw cover using a thin blade at the front end of the device (the end with the buttons)
    • Unscrew the screw and remove it together with its plastic seating
  3. Dual BT 10 Mainboard Disassembly, Removing the front housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dual BT 10 Mainboard Disassembly, Removing the front housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the rubber strap to remove it from the silver front housing
    • Pull the silver front housing from the main body of the device
    • Do so gently as some cables are still connected inside the housing
  4. Dual BT 10 Mainboard Disassembly, Disconnecting the components: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dual BT 10 Mainboard Disassembly, Disconnecting the components: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect all cables:
    • Take a picture of how everything is plugged in to make reassembling easier
    • Disconnect the battery first (fat red/black cable, red socket)
    • Disconnect the two front speakers (blue/white cables)
    • Disconnect the Subwoofer and LED cable (brown/black, red/black cables)
  5. Dual BT 10 Mainboard Disassembly, Removing the antenna wire: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red antenna wire by loosening it from the marked plastic taps
  6. Dual BT 10 Mainboard Disassembly, Unscrewing the front mesh: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dual BT 10 Mainboard Disassembly, Unscrewing the front mesh: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dual BT 10 Mainboard Disassembly, Unscrewing the front mesh: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws holding the front mesh
    • Separate the black plastic from the silver part
    • There is a cable connecting both parts! Be careful.
    • The mainboard is not screwed in place and will be loose after this step
    • Disconnect the brown cable from the small PCB to fully remove the black plastic
  7. Dual BT 10 Mainboard Disassembly, Removing the main board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the main board from the assembly
    • Carefully feed the antenna wire through its small hole if needed
  8. Dual BT 10 Mainboard Disassembly, Reassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reassemble the device, follow all steps in reverse order
    • When reinserting the motherboard, be careful to place it inside the plastic guides in the black plastic / mesh cover
    • When pluging in all cables, it is recommended to plug in the battery last (thick red/black cable, red socket)
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Skyfighter
crwdns2935283:008/28/23crwdne2935283:0
439 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 203
