Droid Ultra XT1080 Battery Replacement
  1. Droid Ultra XT1080 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SIM card tray from the side of the device using a plastic opening tool.
  2. Droid Ultra XT1080 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After properly removing the SIM card tray take your spudger and press it in between the plastic case and the frame of the device until you hear a snap.
    • Work your way from the top and the other side to confirm all the clips are disconnected.
    • Be gentle when performing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Droid Ultra XT1080 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the top and bottom screws are removed remove the top and bottom plastic pieces that were secured to the device.
  5. Droid Ultra XT1080 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin to gently pry up the battery from the frame with a plastic opening tool to release it from its adhesive securing.
  6. Droid Ultra XT1080 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four T5 Torx screws securing the motherboard.
  7. Droid Ultra XT1080 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Droid Ultra XT1080 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry the motherboard out of the frame using the nylon spudger.
    • Make sure not to damage the LCD cable in the process.
  8. Droid Ultra XT1080 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the LCD cable with a spudger from the motherboard by gently lifting up the two connectors.
knoyes
crwdns2935283:010/30/18crwdne2935283:0
785 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G8, Peak Fall 2018 crwdns2935289:0UMass Dartmouth, Team S3-G8, Peak Fall 2018crwdne2935289:0
UMASSD-PEAK-F18S3G8
crwdns2942667:0crwdne2942667:0 3,197
