Drill Master Heat Gun Heating Coil Replacement
  1. Drill Master Heat Gun Heating Coil Replacement, Heating Coil: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Heating Coil Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Heating Coil Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Drill Master Heat Gun Heating Coil Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Drill Master Heat Gun Heating Coil Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Heating Coil Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Heating Coil Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic casing from the end of the barrel.
  6. Drill Master Heat Gun Heating Coil Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal casing from the heating element.
  7. Drill Master Heat Gun Heating Coil Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly remove the heat resistant wrapping from the heating element.
    • Be careful here - the wrapping can be easily torn!
  8. Drill Master Heat Gun Heating Coil Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Drill Master Heat Gun Heating Coil Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    $3.99
    • Use the angled tweezers to remove the heating coil end from the input point.
  9. Drill Master Heat Gun Heating Coil Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heating coil by unraveling it from the heating element.
    • To replace, you'll need to re-wrap a new wire around the coil and attach it to the wires at the bottom (see Step 8).
    Hi,
    it looks like there is a thermal fuse between the end of the blue cord and the heating element. Would it be possible to get the specifications or any other data which is written on it?
    Thank you.
    best wishes,
    berthold
    kauf habmalnefrage - crwdns2934203:0crwdne2934203:0
    AUP0 AF133
    Tf133°C G1
    Silver casing, red lettering, black forward-most plastic “nose” bit
    Kyle Russer -
    Will the gun still blow air if the heating coil is removed? I just need the air blowing function of a mini heat gun; focused air stream for crafts.
    Susan Noguchi - crwdns2934203:0crwdne2934203:0
Mikayla Kim
crwdns2935283:001/31/17crwdne2935283:0
523 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-2, Campbell Spring 2017 crwdns2935289:0University of North Texas, Team 1-2, Campbell Spring 2017crwdne2935289:0
UNT-CAMPBELL-S17S1G2
Where are the heating coil wires found?
Thomas Frye - crwdns2934203:0crwdne2934203:0
I am asking where I can find a NEW heating coil wire?
There is continuity in the heating coil wire, so I believe something else is causing my problem. There is one terminal on the heating element
that has a curved, rigid, bulbous hotdog shaped component that is right close to the terminal on the heating element. I am not sure what it is.
One can be seen in the picture at the top of the page in the introduction.
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 79
crwdns2942667:0crwdne2942667:0 5,200
